I want to supply VOD3120AB with a voltage of 24v/2A from Power Supply. What is the value of the Resistor that I must add to the VCC of the VOD3120AB so that the VOD3120AB works properly?
Information from the datasheet like this:
  1. Wide operating VCC range: 15V to 30V
  2. ICC = 3.5 mA maximum supply current
  3. Output power dissipation Pdiss 250mW
I tried to calculate like this:
R = V/I = 24/0.0035 = 6857 ohm
P = I^2 * R = (0.0035^2) * 6857 = 0.084 watt
I must select R with resistance 6857 ohm and power dissipation = 0.084 watt. Maybe Resistor 6k8/0.125 watt, Its correct?
You are thinking about this incorrectly. Just supply the device with 24 volts and that is sufficient. It'll take a quiescent current of less than 3.5 mA and it's job done. Test circuit from data sheet: -
The maximum power dissipation is the losses of the device when driving a fully rated load such as a MOSFET's gate-source capacitance. Make sure you don't exceed this value by choosing your MOSFET and operating frequency carefully.
You can apply 15 V to 30 V to the Vcc pin, and the device will draw whatever current it requires - no need for any current limiting resistor there.
However, the input seems to be an LED, so you will need to add a current-limiting resistor in series with it to limit the LED current to 7 - 16 mA, as stated in the "Recommended Operating Condition" table.
If you're referring to powering the LED from 24V, first pick the desired current, say 20mA and use Ohm's Law.
$$ E = I \cdot R $$
$$ 24V = 0.02A \cdot R $$
Then realize that a forward-biased LED is going to drop some voltage, say 1.8V when powered at 20mA. So subtract this from the supply voltage.
$$ 24V - 1.8V = 0.02A \cdot R $$
$$ 22.2V = 0.02A \cdot R $$
Then rearrange to solve for R by dividing both sides by current (the opposite of multiplying current, so R is left by itself on the right side.)
$$ \frac{22.2V}{0.02A} = \frac{\require{cancel}\bcancel{0.02A} \cdot R}{\bcancel{0.02A}} $$
$$ \frac{22.2V}{0.02A} = R $$
$$ 1110 \Omega = R $$
  • \$\begingroup\$ I have to keep the input (left) and output (right) with different ground (different power supply), because the input side will be connected to the microcontroller with a voltage of 3.3v and a current of 10mA, while the output side will be connected to a voltage of 24v and a current of 2A . Intentionally isolated so that the large electric current from the MOSFET does not damage the microcontroller. Thank you. \$\endgroup\$
    – Ihdina
    Jun 21, 2022 at 20:27
