I want to use one of those tilt-ball switches on an interrupt with a microcontroller that can only trigger an interrupt on a signal FALLING from high to low, in a low power circuit.
The tilt ball switch is normally closed but this cannot be relied upon.
Basically it needs to trigger a low pulse whenever the signal from the switch changes from high to low or low to high but normally be high or high-Z, and not burn significant current in the long periods of time waiting for this to happen.
