I am referring to the internal communication example for ESP mesh from the last two weeks but I am unable to make connections between two ESP32-C3, one as the root node and the other as the parent node, and even not able to send data between the two devices. I am using ESP-IDF.
I have used the following procedure:
- I set the type of the first ESP32-C3 as root node (MESH_ROOT) using
esp_mesh_set_type
inapp_main()
and I am sending the message "hello world":static char tx_buf[TX_SIZE] = "{\"Hello\":\"World\"}"
. - For the first ESP32-C3 (as the root node) I have provided router credentials and set MESH AP connections to 1 from 6 using menuconfig.
- I set the type of the second ESP32-C3 as parent node (LEAF_NODE) using
esp_mesh_set_type
inapp_main()
I have shared to OUTPUT screenshots; please find the attachments.
Questions:
- Is the procedure I have followed valid?
- Are there any other parameters to set or am I missing some parameters?
