These are the connectors used to power a 12V fan. I have both male and female ends attached. Does anyone know the name of it? I'd like to purchase a extension cable. It has 8 pins because there are two fan blades. here is its datasheet: https://www.delta-fan.com/Download/Spec/GFC0412DS-SM06B0G.pdf
    \$\begingroup\$ Measure the pitch. It looks like Molex Picoblade, or any other equivalent 1.25mm pitch connectors. \$\endgroup\$
    – Lior Bilia
    Jun 23 at 0:16
  • \$\begingroup\$ Could be a JST connector \$\endgroup\$ Jun 23 at 11:46
It looks like a Picoblade except for the mounting tabs - could be a clone - but without knowing the pitch I can't say for sure. Picoblade is a wire-to-board connector; there are no free hanging male pin headers. Your options to make an extension cable are to:
  1. Buy a through-hole male pin header (the socket), a matching housing (the plug), and pre-crimped jumper wires (I assume you don't want to drop $600 on a crimper). Cut off one end of the jumper wires and solder straight to the pins on the header. Good luck insulating it.
  2. Buy a suitable breakout board and solder the header into it, solder the jumper wires into the board.
  3. Cut the cable and individually splice each wire.
