I would like to send ~100W through an RF filter. Can you estimate the current passing through the shunt component without a circuit simulation assuming a reasonably high S21 value?
MLCC's are cheap, even at higher voltages. Inductors are expensive and high-power inductors even more so.
Questions:
In the case of a high-pass (pi or tee) filter where the shunt components are inductors, just how much current actually flows through the shunt inductors?
I would think the power moving through the inductor is low because the loss is low (nearly lossless S21), but is that a correct assumption?
If very little current (<100mA RMS) actually flows through the inductors, then can less expensive and small (like 0402) low-current high-Q RF inductors can be used?
There are 2 votes-to-close this question :( ... but I don't understand why this should be closed because I'm seeking to understand the principle here and not just shove it through a simulator and get the answer, so please read on:
The principle seems to make sense that almost no current passes through a shunt if nearly all the signal goes through the filter. I'm trying to understand why shunt current could be present in this case. Simulations are great, but they don't provide the understanding---just the result. This question is about understanding if (and why) a nontrivial amount of current would pass through a shunt component in the presence of a nearly lossless S21.
