I am designing a board with the DRV8837 IC, which has an 8-WSON package with a thermal pad and 2 vias. When running the DRC, I am getting the following error:
Minimum Solder Mask Sliver Constraint: (0.097mm < 0.114mm) Between Via (120.867mm,7.48mm) from Top Layer to Bottom Layer And Via (121.767mm,7.48mm) from Top Layer to Bottom Layer [Top Solder] Mask Sliver [0.097mm]
It's really weird, it says the sliver error is in the thermal pad, where there is no mask at all:
This is the component in the PCB Lib, in case it's too messy to see it in the other picture with all the tracks:
