I try to recreate the circuit from here using discrete components logic gates. How can I avoid these parasitic oscillations in a square wave in one of its outputs?
3\$\begingroup\$ It's not oscillation, just capacitive coupling. Set the source risetime to a more realistic value like 10 or 100ns. And 10V like the supply I guess. \$\endgroup\$– Tim WilliamsJun 25 at 8:06
\$\begingroup\$ For a proper simulation of a discrete circuit with such speeds, you must include parasitic inductance of the interconnects which is in the ballpark of 10 nH and more for almost each of the interconnects. \$\endgroup\$– tobaltJun 25 at 8:09
1 Answer
Your design has the wrong threshold to act as Schmitt Triggers on slew-rate limited pulses in order to create "complementary-exclusive transitions" or a "deadtime control circuit."
The transistor delays in your simulation cause these glitches from the XOR arrangement of components.
There are many ways to correct this error.
If the rise time is above the transistor delays, you might prevent this or make it worse
define the hysteresis with resistor ratios. in a Schmitt trigger
and input slope to exceed propagation delay. This is similar to what you have used but without the added positive feedback R's. \$V_{HT}=V+ \dfrac{R_E}{R_E+RC1}\$
you need to specify your dead time by slew rate and thresholds then redesign according to this logic.
(from your linked earlier question)
(Design Specs are a priori is my motto then test and verify results)
suggestions
- logic diagram has excessively long connections and could be improved for readability. Compare with the example above.
- trace diagram cropped of critical time base information, show all results in future.
- it is much easier with CMOS logic.
\$\begingroup\$ Hi sir, quoting from "The transistor delays in your simulation cause these glitches from the XOR arrangement of components.", does this mean that this will produce un-even deadtime between the 2 complementary waves if discrete components (discrete transistors are used) ? Thank you:) \$\endgroup\$ Jun 28 at 2:56
