In the circuit I am working on there is a requirement to create 30V DC source for a very light load (couple of mA max). I am aware that there a specialized ICs that can do that but I would like to achieve that with the parts that I already have.
What I came up with is this:
The idea is that 555 IC configured in astable mode drives a voltage multipler (configured as tripler on the schematic), a fraction of output voltage is compared with known source (1/3rd of 15V) via an op amp and the amplified error is fed into NPN so that when base voltage is ~0 control and reset pins of 555 IC are triggered.
Simulation in LTSpice does produce a desired output:
And a closer loot at 555out:
The 15V and -15v are generated at the same time with two MC34063 hence they are not stable at the startup:
What I was wondering is:
- Is there any reason this circuit would fail in the real life?
- Are there any possible improvements that might simplify/improve the schematic?
