Can anyone help me figure out as to why I'm getting don't cares? I think it's not reading the signaldata.txt file which is why it prints don't care.
`timescale 1ns/1ps
`include "uvm_macros.svh"
module tb_top();
    import uvm_pkg::*;
    reg clk, rst;
    //DDFS module to generate 1 MHz Sine and Cos wave
    wire signed [15:0] sin, cos;
    wire [19:0] fcw;
    assign fcw = 20'b00000000100000110001;
    ddfs DDFS2(clk, rst, fcw, sin, cos);
    //constants
    int ADC_SAMPLE_SIZE = 65536;
    int i, I, Q, amplitude;
    //I, Q initialize to 0
    initial begin
    I = 0;
    Q = 0;
    end
    int fd, j;                           // file descriptor and iteration variable
    int arr[65536];                      // integer array to store the 16-bit binary values
    initial begin
    j = 0;
    fd = $fopen("signaldata.txt", "r");   // signaldata.txt contains 65536 16-bit signed binary
                                             values
    while (!$feof(fd)) begin             // loop until end of line to cover all 65536 values
    $fgets(arr[j], fd);
    j = j + 1;
    $display("%16b",arr[j]);  // I get all don't cares printed here instead of binary values
    end
    $fclose(fd);
    end
endmodule
This is what signaldata.txt looks like. There are 65536 values in total.
0000000000001100
0000000000000100
1000000000110100
1000000000010100
0000000000011100
1000000000010100
0000000000000100
1000000000110100
0000000000011100
0000000000010100
1000000000110000
0000000000010100
1000000000000100
1000000001000100
1000000000110000
The problem with reading the signaldata.txt file is that you are using the wrong tool for the job. You should use $readmemb instead of $fgets. $readmemb is designed to do exactly what you want: read a text file with numbers in binary format.
module tb_top;
    initial begin
        $readmemb("signaldata.txt", arr);
        for (int i=0; i<10; i++) $display("i=%0d %b", i, arr[i]);
    end
endmodule
This is the output:
i=0 00000000000000000000000000001100
i=1 00000000000000000000000000000100
i=2 00000000000000001000000000110100
i=3 00000000000000001000000000010100
i=4 00000000000000000000000000011100
i=5 00000000000000001000000000010100
i=6 00000000000000000000000000000100
i=7 00000000000000001000000000110100
i=8 00000000000000000000000000011100
i=9 00000000000000000000000000010100
