I am testing an SPX3819M5-L-3-3 LDO in SOT-23-5 pkg. Its max. Vin is from 2.5 V to 16 V. I need 300 mA, so as a load I connected Vout to a 10 Ω, 10 W resistor to GND.
When I input Vin more than 6 V, the output voltage Vo begins to drop. According to the data sheet spec. table I should get about 0.6 V drop at around 300 mA. According to the charts I should be around 3.3 V.
Vin Vo Io 9 V drops from 3.3 to 1.8 V 173 mA 8 V drops from 3.3 to 2 V 200 mA 7 V drops from 3.3 to 2.6 V 250 mA 6 V stays at 3.3 V 311 mA
If I cool it with an air can, Vo goes back to 3.3 V. Any ideas why at higher Vin, Vo drops so much?
