A guitar pickup is a coil of wire with some magnets in the middle. The magnets magnetize the steel guitar strings. When those strings a strummed, they vibrate, and since they're magnets they induce a small current in the coil. So far so good.
Let's assume the coil is wound clockwise, and it is a single coil pickup.
When the string moves right, it causes current the flow right. On the top part of the coil, that means clockwise, but in the bottom, that means counter clockwise.
Should those two opposite currents cancel out to zero?
As the string quickly moves left and right, each time its pulling the electrons in that direction on the top and bottom parts of the loop. And if its a middle string it probably doesn't affect the sides of the coil much.
So guitar pickups shouldn't work. But they definitely do. What is wrong with my explanation?
This question probably applies to most transducers.
    \$\begingroup\$ A very warm welcome to the site. Please can you edit your question and insert a diagram to clarify your description for readers. Otherwise, they're having to imagine what you might mean and draw it in their head. Don't forget to add a link to where you got the image from, for the site rules. Thanks. \$\endgroup\$
    – TonyM
    Commented Jul 6, 2022 at 6:19
  • \$\begingroup\$ "When the string moves right" - when I play guitar I hold the guitar horizontally and my strings don't move right or left. They vibrate up and down. \$\endgroup\$
    Commented Jul 6, 2022 at 8:17
  • \$\begingroup\$ When you say 'top and bottom' pickup, do you mean the two pickups in a humbucker, or do you mean bridge and neck pickup? \$\endgroup\$
    – RJR
    Commented Jul 6, 2022 at 9:12
Your explanation with the top and bottom induction seems to be somewhat off.
The guitar string is part of the magnetic circuit comprised of:
  • the magnet
  • the string
  • the air between and around
This magnetic circuit channels some magnetic flux through the coil.
When the string vibrates, the amount of flux going through the coils changes, because the magnetic circuit changes.
This flux change causes a proportional induction voltage between the coil terminals. The induced current is therefore equal in the entire coil.
