I have a custom electromagnet that we are using in a system under development. It is powered with 2.25 VDC and draws about 1 A at that voltage level. We need to periodically reverse the current direction on this electromagnet and are planning to use a Toshiba TC 78H653FTG dual h-bridge driver to allow us to use the microcontroller to reverse the direction.
The main system power is from a 12 VDC battery. Ideally, I'd implement a 2.2, 2.3 or 2.5 V linear regulator but none are available that provide the required current.
I'm considering using an LM7805 5 V regulator with a passive voltage divider but hate the idea of the power being wasted using this method. What other options do I have?
