I am designing my first 4-layer PCB and I have a question related to the plane on the bottom of the board.
At this moment, my plane stack-up is :
- Signal traces + ground fill
- Ground plane, no traces
- 5 V plane, no traces
The board contains a few different voltages, but except for the 5 V connected to almost every part, they are generated and used in localised area. I was then wondering if I could use the bottom copper to define multiple power planes around where they are used and created. They could also act as thermal dissipator.
However, I do not know if it is recommanded or not, and if it can cause some unwanted effects. My circuit does not have high frequencies components except for a few components using 10 MHz signals.
