Does the module shown above provide all the filtering needed by 3.3 V devices to operate correctly? I think I have seen circuits with additional electrolytic capacitors on the output side. Are those really necessary, or are they overkill?
The power source is a 5 V switched power supply located within a couple of inches. The devices to be powered include a HC-12 transceiver, and possibly a temp/pressure sensor, an audio player, and a 100 mW FM transmitter, all located within a couple of inches.
All the devices consume stable (voltage) DC; the FM transmitter, temp/pressure and audio player consume stable current of 56mA total. The HC-12 transceiver consumes 15mA when receiving and 100mA when transmitting. HV-12 details can be found here: https://wolles-elektronikkiste.de/en/hc-12-radio-module (I am running it at 3.3V due to the other things it interfaces with).
