I have a 40-year old microwave oven. I temporarily attached a magnetic flashlight to the side of it. Its 5/8"-diameter magnet is likely a neodymium magnet, strong enough to secure the 10-ounce flashlight to a metal surface from falling down.
After that, the oven made a humming/buzzing sound when used, and I considered the magnet and removed the flashlight from the side of the oven. The humming disappeared the next time I used the oven, but now I noticed once in a while that the oven doesn't heat at all, or it begins heating several seconds after starting it instead of heating right away (you can tell by the turntable motor's change of sound pitch and the slight dim of the kitchen's lights).
I estimate the magnet was several inches away from the magnetron (I have repaired this oven in the past). So my questions:
Could I have damaged the magnetron with the magnet being that far away? If so, is there any simple way to re-magnetize the circular ceramic(?) magnets of the magnetron?
Why would/how could the occasional heating problem be intermittent and infrequent?
Edit (conclusion): The final issue was a broken solder connection on the motherboard causing the intermittent heating. The flashlight and heating issue was apparently a coincidence.
