6
What in the structure of a MOSFET prevents leakage current flowing from the drain to the gate of a MOSFET when the drain is at a higher potential than the gate? I am assuming that drain-to-gate leakage current doesn't exist at all because it seems to me that if it did it would be a central MOSFET datasheet parameter as this current from the drain could charge the gate and turn the MOSFET on. If however drain-to-gate leakage does occur as a very small current, what keeps it from ever being a consideration in circuit design or in component evaluation?
4 Answers 4
8
I'm answering the question of how a power MOSFET can let you have e.g. a 500V Vdg while Vgs is limited to 20V.
Power MOSFETs have an asymmetric vertical structure, like this:
Vertical MOSFET structure
The breakdown voltage is determined by the characteristics of the N region between the drain and gate. The maximum current is determined by the size of the channel. In a vertical MOSFET, these can be varied separately, so you can have both a high on current and a high breakdown voltage.
There are two familiar cases here:
  1. The usual integrated circuit (IC) case, where lateral MOSFETs are formed, covered in gate metal/oxide, over the whole channel;
  2. Power MOSFETs, which are made in more compact/highly optimized structures, offering much higher voltage ratings (silicon parts are available rated 2500V or more!).
The other answers have covered #1 more or less, I think, and this is perhaps the less interesting case: in ICs, Vgs and Vds are almost always only within VDD to VSS. It doesn't really make sense to think of leakage from a channel that's not higher in potential than the gate anyway.*
So I also suspect your question may be more angled towards #2. Note that IC-style MOSFETs are essentially unavailable as discrete components -- almost any MOSFET you see on a board, will be some type of power MOSFET.
And as for power MOSFETs -- There is a fairly obvious(?) disconnect, I think, between the usual cartoon of a MOSFET (gate lapped over the whole channel), and a power MOSFET that obviously is handling a whole hell of a lot more than the, whatever, 20V say that the gate oxide is rated to handle! So what are they doing?
Two things. Back in the bad old days, when MOSFETs were still new, lateral MOS was indeed still the technology of the day. To handle the higher voltages, gate metal simply wasn't deposited over much of the channel length; instead, a heavier oxide layer, and a "field plate", tied to drain, was placed there. This effectively biases that part of the channel on, but with much less gain (read: less electric field per volt -- again, thicker layer), and so voltage can distribute along the channel, well, if not better necessarily, then differently at least. (I'm not sure exactly what designs they did of this; it would also make sense to have a tapered oxide under the field plate, but I don't know that any stereolithography process has ever made a sloped oxide surface; that would be very difficult to fab the usual way, at the very least.)
I don't know enough about laterals, to say what kind of ratings they achieved; maybe a couple hundred volts?
Note that, meanwhile, the channel diffusion itself is deeper, lighter, less abrupt -- just as the case for a higher voltage diode or BJT.
I was about to explain modern vertical (VDMOS) here, but I see @AdamHaun has beat me to it! In that case, the voltage is dropped across the p- epi, and, I suppose the oxide at the bottom of the trench could be thicker, though I don't know that that's done..?
Anyway, the structure very much resembles any other high voltage device -- diode or BJT -- where there's a large drift region of lightly doped (sometimes intrinsic even, as for some rectifiers -- though I don't think transistors can use intrinsic, so, not quite that low doping) semiconductor, across which most of the voltage is dropped (depletion region), and then there's a tiny bit of hardware at the surface, shooting charges (electrons/holes) into that depletion region.
The figure (https://i.sstatic.net/c3pBM.png) I think is not to scale; the gate stuff is actually all very small, i.e. 100s nm wide, and perhaps a few times taller (not sure of the exact dimensions; and it does vary with process of course), while the drift region is several to 10s of µm tall. So this allows the electric field to drop mostly through the bulk, without building much additional E-field at the base of the gate trench, so that breakdown (avalanche), when it does occur, doesn't cause too much stress around the gate, which might lead to failure.
*There is a different gate leakage mechanism, known as "hot carrier injection". I'm not real big on the details of this myself, but it has to do with operating a transistor very near its process limits (close to breakdown); the high electric field accelerates the carriers crossing the channel (i.e. raising to higher energy levels: hence "hot"), and these high energies being generally present in the area, allows some to tunnel or diffuse into nearby structures -- even through fairly high energy barriers, like SiO2 (an insulator, i.e. electrons don't move very far through it normally!). This phenomenon allows depositing charge into an otherwise fully unconnected piece of metal placed near/on the channel: thus a floating-gate EPROM cell can be formed. The deposited charge, of course, biases the gate, so that when normal gate voltages are applied to the second (wired) gate, the transistor may read as on or off, and thus a bit of information can be stored, persistently. This usually needs similarly drastic means to relieve the charge -- UV exposure for example (photoelectric effect) -- but electronic methods have also been developed, hence EEPROM and Flash. (I've not read up on these in a long while, actually, so I will hold off on attempting an explanation; others can chime in.)
The significance of this effect, can also be seen in MOSFETs: at high Vgs (above ratings), carrier injection can occur due to the few carriers that do leak across the barrier; if they get stuck, a permanent shift in Vgs(th) results. Of course, if too many get stuck in one place, a defect can form; or if too many flow in a local region, same idea, and gate rupture occurs. Vgs(max) is rated to avoid both effects.
Likewise, the hot-carrier (channel) effect can cause shift in Vgs(th), or eventual failure. While many MOSFETs are rated for avalanche robustness, take care that those ratings are indeed one-time -- typical parts only survive a few such hits before destruction. And repetitive avalanche can cause incremental wear, by trapping charges in the oxide. This is why I always recommend control of Vds: if it cannot be ensured in normal operation (e.g. with adequate supply bypass, design of the switching loop, etc.), then a clamp diode or TVS should be added to sink the excess, avoiding avalanche operation. (TVS diodes are made with careful control of trapping sites, so can withstand essentially unlimited avalanche.)
(Supposedly, some MOSFET types are more robust than others, in terms of repetitive avalanche. But I haven't seen a good argument for why this might be, or how to identify them. One explanation could be, avalanche is made to occur in the space between gate trenches, so the hot carriers are relatively distant from it; but I don't know what families, if any, have such a feature.)
    \$\begingroup\$ As far as I understand the bottom of the gate trench doesn't need to have thicker oxide because, when off, the bulk of the drain-source voltage is dropped over the drift region and not over the channel. \$\endgroup\$
    – tobalt
    Commented Jul 11, 2022 at 18:17
    \$\begingroup\$ This is a great answer; much better than mine, I think. Regarding EEPROM/flash erase: In the flash memories I've worked on, erase (removal of electrons from the floating gate) is done using Fowler-Nordheim tunneling. A very high voltage (on the order of 15-20V) is applied between the control gate and the body, causing the trapped electrons to tunnel through the oxide. NAND flash also uses F-N tunneling for programming by applying a high voltage in the reverse direction. \$\endgroup\$
    – Adam Haun
    Commented Jul 12, 2022 at 16:29
  • \$\begingroup\$ @AdamHaun Ah yeah, zap the channel to write, zap the gate to erase, that makes sense. \$\endgroup\$ Commented Jul 12, 2022 at 19:02
The drain to gate (and source to gate) resistance comes about because of the 'O' in 'MOSFET'. This drawing (By Brews ohare - Own work, CC BY-SA 3.0) shows a schematic of the MOSFET structure.
image of a MOSFET showing source, drain, bulk and gate connections, and the oxide layer between the channel and the gate
The pale layer between the gate (G) and the channel (between the source and drain, S and D respectively) is insulating -- in a silicon device, it's silicon oxide, so it's basically glass or quartz. That layer is a good insulator.
This doesn't mean the insulation is perfect - any two electrical conductors will leak a little bit. In the case of most discrete MOSFETs, the leakage is utterly insignificant compared to the intended usage of the part. Most MOSFETs are intended as power devices, and gate drives need to have very low impedances to drive the gate quickly enough.
If someone were selling you a FET where the isolation between the gate and source or drain is a selling point, then they'd be sure to tell you -- and they'd have recommended board layouts for you because when you get to that point the board can potentially leak more than the part itself.
    \$\begingroup\$ What makes the drain-gate leakage so much smaller than the gate-body leakage, then? Gate-body leakage is often listed in datasheets as being in the 10s of uA. Vdg is in most use cases much higher than Vbg so if the oxide-as-resistor model were valid here the current between the drain and gate contacts would be higher than that of the body and gate contacts, no? \$\endgroup\$
    – mamawmaw
    Commented Jul 11, 2022 at 16:42
  • \$\begingroup\$ Could you edit your question to include that vital bit of information? You're getting beyond my knowledge of FETs -- I buy little black things with three or four contacts, and I design boards around them. It sounds like you might be speaking of MOSFETs inside of ICs? \$\endgroup\$
    – TimWescott
    Commented Jul 11, 2022 at 16:44
  • \$\begingroup\$ Yes I will edit the question. Its only through your response and the others that I am able to better articulate my question, so thank you, I do value your feedback a lot. \$\endgroup\$
    – mamawmaw
    Commented Jul 11, 2022 at 16:56
    \$\begingroup\$ @mamawmaw if a datahseet gives only a max value and no typical value (especially for leakage specs), such as max. 10 uA, that means: 1) design your circuit to tolerate 10 uA leakage 2) they give a large value, so they can skip the cost of production testing 3) the actual value is likely orders of magnitude lower. \$\endgroup\$
    – tobalt
    Commented Jul 11, 2022 at 17:23
There is an insulating oxide layer between the gate and the source/drain structures. As long as you don't apply a high enough voltage to breakdown that oxide layer the leakage current flowing through it should be extremely small (nanoamperes, for example).
    \$\begingroup\$ The question of why the gate-to-drain breakdown voltage is so much higher in a typical MOSFET than the gate-to-source breakdown is one that might be worth answering as well, though I don't have the time to answer it myself. \$\endgroup\$
    – Hearth
    Commented Jul 11, 2022 at 15:35
    \$\begingroup\$ Yes but couldn't even these nanoamps tunneling through the oxide from the drain charge the gate? I guess my question is then what parasitics (resistances to ground, for example) of the MOSFET keep the capacitance at the gate from being charged to an arbitrarily high voltage by the current tunneling through the oxide? \$\endgroup\$
    – mamawmaw
    Commented Jul 11, 2022 at 15:48
    \$\begingroup\$ The gate will typically be connected to some other circuitry that can supply much more than nanoamps and thereby maintain the gate voltage at the appropriate level. If you just leave the gate unconnected then yes, the leakage current could have a noticeable effect, but nobody does that in practice. \$\endgroup\$ Commented Jul 11, 2022 at 16:21
