As far as I know, normally when you directly supply the circuit, it must have decoupling capacitors to deal with noise. If I use an LDO instead of directly supplying it, do I need to have decoupling capacitors? In most datasheets they will recommend the best value of capacitor for best stability. Since inside most of LDOs is a CMOS FET, I am concerned that adding more capacitance (decoupling) than recommend is going to mess up the capacitance of the LDO input. Am I just worrying too much?
Here is my circuit LDO is driving ICs about 350mA max, supply is given to the terminal block (J4):
