I've got a 220v dust collector (shopfox w1666) that consistently blows the internal 18amp fuse shortly after it turns on. Video here:
https://i.sstatic.net/KyB6S.jpg
I think this started happening after I had plugged it in while it was switched on. There was some burn marks and pitting on the plug after it arced when I did that.
I've replaced the fuse and the motor start capacitor but that hasn't helped.
What is the likely source of this issue? what steps can I take to debug it further?
I have a pretty rudimentary ability to diagnose and resolve electrical problems, and hope that this question is appropriate for electrical engineering stack exchange!
Run capacitor would be a suspect (50uF/350V it looks like, get a replacement from Grizzly or their recommendation).
Or the motor may have an internal shorted winding.
  • \$\begingroup\$ I've already replaced the capacitor, first with a generic one off ebay (200MFD 250VAC CD60A 200uF, TMC UL) and then with the official one from grizzly PX1666008A-1 \$\endgroup\$
    – schpet
    Commented Jul 16, 2022 at 16:36
  • \$\begingroup\$ are there steps i can take to determine if there's a shortened winding? is this something i can fix myself, or take somewhere to fix? \$\endgroup\$
    – schpet
    Commented Jul 16, 2022 at 16:39
  • \$\begingroup\$ RUN capacitor not start capacitor. If the motor has a shorted winding it is not economical to repair so you would replace it. \$\endgroup\$ Commented Jul 16, 2022 at 17:56
    \$\begingroup\$ ah ok, i don’t believe this w1666 has a run capacitor - i see the older generation did but i am not seeing one i could replace. appreciate your attention on this, sadly sounds like it won’t be fixable \$\endgroup\$
    – schpet
    Commented Jul 17, 2022 at 20:07
