I have two voltage sources V1, V2
I want my output voltage to be 4V2 - V1
Im using a single op-amp and up to 4 resistors: (Only one is shown here and It's set as 10k Ohm) I can add 3 more.
I know how to create functions where I sum only negative voltages ( -V1 -4V2 - V3 ...) But I have no idea how to execute what I mentioned above, any help would be appreciated ! thanks.
My try:enter image description here
Which sorts out the -V1 part of my output, but gives only 2*V2. I don't know how to procceed.
  • \$\begingroup\$ @devnull up to 3 resistors. I will edit my post \$\endgroup\$ Jul 17 at 13:13
  • \$\begingroup\$ Edward, I wonder what is the name of the simulator used for the schematics above? (I also posted an answer below). \$\endgroup\$
    – ee_student
    Jul 17 at 13:48
I don't know how to proceed.
This should work if I'm not too mistaken: -
If you need to use 4 resistors then 2 parallel 10k resistors = 5k. Now, all resistors are the same value too.
  • \$\begingroup\$ This indeed works for me, I'm Still trying to figure out the thought proccess which led you to the solution. thank you! \$\endgroup\$ Jul 17 at 13:50
    \$\begingroup\$ @EdwardJosef ah the good-old thought process!!! I'm unsure myself other than to say "experience". \$\endgroup\$
    Jul 17 at 13:53
  • \$\begingroup\$ I'd add a 5k resistor in series to the negative input to compensate for DC offset. \$\endgroup\$ Jul 17 at 16:01
  • \$\begingroup\$ @F.Heisenberg I think you mean the non-inverting input (only needed for crappy op-amps with poor input bias currents). \$\endgroup\$
    Jul 17 at 16:11
  • \$\begingroup\$ Sorry of course I meant the non inverting input \$\endgroup\$ Jul 17 at 16:12
You pretty close, here's a circuit that does 4V2 - V1.
Here's a link to the Falstad circuit simulator for this circuit: simulator link
The top op amp multiplies by 4, the bottom one multiplies by -1.
4*V1 and -1*V2
The middle between the 10k resistors is the average:
(4*V1 - 1 * V2) / 2
The last op amp multiplies by 2:
((4V1 - 1 * V2) / 2) * 2 = 4V1 - 1*V2
Could you please share in the comments the name of the simulator you used for the schematics in your question?
  • \$\begingroup\$ It seems there is a constraint: "using a single opamp and up to 4 resistors". \$\endgroup\$
    – devnull
    Jul 17 at 13:48
  • \$\begingroup\$ You're right I see. On the other hand, I believe it was just a statement of the initial parts he's using. \$\endgroup\$
    – ee_student
    Jul 17 at 13:53
An inverting opamp sums inputs. I turned around the inputs so that the inverted output is positive.opamp
