I'm trying to make a guitar pedal and I'm working on the input stage op-amp.
I keep getting a singular matrix error at resistor R5. Also, the simulation states failed to calculate operating point. I'm new to Altium Designer, so I'm not sure what these mean.
I have taken a look at this post regarding singular matrix issues, but I don't think those solutions apply to my circuit.
After the simulation message, Altium tends to just crash a few seconds later. When it does output a plot, it's just a flat line at 0.
Here's the picture of my circuit and the simulation messages:
I appreciate any tips or advice for my circuit or this issue.
EDIT Here's the updated netlist with the right op-amp model for future reference to this post.
Guitar_Pedal_Project
*SPICE Netlist generated by Advanced Sim server on 7/21/2022 9:09:35 AM
.options MixedSimGenerated
*Schematic Netlist:
CC1 NetC1_1 NetC1_2 .1u
CC2 NetC2_1 0 4.7u
CC3 NetC3_1 0 6.8n
CC4 NetC4_1 NetC4_2 270p
CC5 0 NetC5_2 6.8n
RR1 0 NetC1_2 1M TC1=0 TC2=0
RR3 NetC1_1 NetC3_1 4.7K TC1=0 TC2=0
RR4 NetC2_1 NetR4_2 4.7K TC1=0 TC2=0
RR5 NetC4_2 NetC4_1 100K TC1=0 TC2=0
RR6 NetC4_1 NetC5_2 4.7K TC1=0 TC2=0
RR7 NetR4_2 NetC4_2 100K TC1=0 TC2=0
RR8 0 NetC1_1 1M TC1=0 TC2=0
XU1A NetC4_1 NetC4_2 NetC3_1 0 ExtraNet_XU1A_5 TL972
VV1 NetC1_2 0 DC 0 SIN(0 1 500 0 0 0) AC .8 0
VV2 NetU1_8 0 5 AC 1 0
.PROBE {V(NetC5_2)} =PLOT(1) =AXIS(1) =UNITS(V)
.PROBE {V(NetC4_2)} =PLOT(1) =AXIS(1) =UNITS(V)
.PROBE {V(NetC3_1)} =PLOT(1) =AXIS(1) =UNITS(V)
.OPTIONS GMIN=1e-9 RSHUNT=1e9
*Selected Circuit Analyses:
.DC V1 1 10 1
.AC DEC 10 1K 1G
.TRAN 80.00u 10.00m 0 80.00u
.OP
*Models and Subcircuits:
* (C) Copyright 2011 Texas Instruments Incorporated. All rights reserved.
** This model is designed as an aid for customers of Texas Instruments.
** TI and its licensors and suppliers make no warranties, either expressed
** or implied, with respect to this model, including the warranties of
** merchantability or fitness for a particular purpose. The model is
** provided solely on an "as is" basis. The entire risk as to its quality
** and performance is with the customer.
* Released by: Analog eLab Design Center, Texas Instruments Inc.
* Part:           TL972
* OUTPUT RAIL-TO-RAIL VERY-LOW-NOISE OPERATIONAL AMPLIFIERS
* Date:           2011-09-12
* Model Type:     PSpice
* Simulator Version:   PSpice 16.2.0.p001
* EVM Order Number: N/A
* EVM Users Guide: N/A
* Datasheet:      SLOS712 - January 2011
* Updates:
* Version 1.0 :
* Release to Web
* The TL972 Macro Model represents the following parameters for
* a 5-V Application:
* AC small-signal response, input-referred voltage noise, the quiescent current
* output swing, input offset voltage, input bias current, PSRR and
* CMRR, and the slew rate
.subckt TL972 INP INN VCC VEE OUT
R_pd          VCC       PD       1m
V_Vos         INP2      INP_CMRR 0.25mVdc
C_Cinn        GND_FLOAT INN1     200f  TC=0,0
X_U10         CL_CLAMP GND_FLOAT PD N118253 GND_FLOAT VCC VEE HPA_PD_SGNL
+  PARAMS: GAIN=1
X_U9          VCC VEE PD VIMON GND_FLOAT INP2 INN1 HPA_PD_I PARAMS: VTH=1.4
+  IMAX=2e-3 IMIN=3N IIBP=0.21U IIBN=0.20U
C_Cc2         CLAW_CLAMP GND_FLOAT  1.5p  TC=0,0
G_G3          GND_FLOAT VSENSE OVER_CLAMP GND_FLOAT 1u
X_Ug0         INP_CMRR INN3 GND_FLOAT N90758 VCCS_LIMIT PARAMS: GAIN=100e-6
+  IPOS=0.5 INEG=-0.5
X_U13         VCC VEE VIMON GND_FLOAT tran_iout
G_G6          GND_FLOAT   CLAW_CLAMP P0ZP1 GND_FLOAT 1m
E_E1          VCC_BUF     GND_FLOAT  VCC   GND_FLOAT 1
C_Cc          OVER_CLAMP  GND_FLOAT  20n   TC=0,0
R_Rinp        INP         INP1       1     TC=0,0
R_R2          GND_FLOAT   N107583    1G    TC=0,0
X_Ugnd        VCC 0 VEE 0 GND_FLOAT  0 EPOLY2 PARAMS: COEFF1=0.5 COEFF2=0.5
E_E2          VEE_BUF     GND_FLOAT  VEE   GND_FLOAT 1
G_Gpsr        GND_FLOAT   N02795 VCC VEE   156.2u
R_Rpsr        N02795      N027510    1     TC=0,0
L_Lpsr        N027510     GND_FLOAT  2uH
X_Upsrr       N02795      GND_FLOAT  INN1 INN2 VCVS_LIMIT PARAMS: GAIN=-1
+ VPOS=20M
+  VNEG=-20M
R_Rcmr        N01819      N013640     1    TC=0,0
L_Lcmr        N013640     GND_FLOAT   560nH
E_Ecmrr       INN2        INN3       N01819 GND_FLOAT 1
X_U7          CLAW_CLAMP  GND_FLOAT  RNOISELESS PARAMS: R=1e3
R_Rinn        INN         INN1       1     TC=0,0
X_Ud2         INN3        N08751     d_ideal
X_U1          GND_FLOAT   N90758     RNOISELESS PARAMS: R=1e6
G_G4          GND_FLOAT   P0Z VSENSE GND_FLOAT 1u
C_Cc3         GND_FLOAT   GND_FLOAT  4.11f  TC=0,0
V_Uvcl_Vclo1  VCC_BUF     Uvcl_N498931 0.89Vdc
V_Uvcl_Vclo2  Uvcl_N50894 VEE_BUF      0.89Vdc
X_Uvcl_Uvcl1  OVER_CLAMP  Uvcl_N498931 d_ideal
X_Uvcl_Uvcl2  Uvcl_N50894 OVER_CLAMP   d_ideal
V_V4          N08964      VEE          1.94Vdc
X_Ud3         N08964      INP_CMRR     d_ideal
X_Uthd        N118253 GND_FLOAT VCLP GND_FLOAT EPOLY1 PARAMS: COEFF1=0.0
+  COEFF2=0.0
C_Ucl_Ccl2    GND_FLOAT   Ucl_N01226   1p  TC=0,0
C_Ucl_Ccl1    Ucl_N01131  GND_FLOAT    1p  TC=0,0
V_Ucl_Vclp    Ucl_N00774  GND_FLOAT    1.4Vdc
V_Ucl_Vcln    Ucl_N00760  GND_FLOAT   -83Vdc
X_Ucl_Ucl1    Ucl_N50037  Ucl_N01131   d_ideal
E_Ucl_E1      Ucl_N01131  GND_FLOAT  Ucl_N00774 VIMON 100
R_Ucl_Rcl1    Ucl_N01131  N127440      1   TC=0,0
X_Ucl_Ucl2    Ucl_N01226  Ucl_N50037   d_ideal
E_Ucl_E2      Ucl_N01226  GND_FLOAT  Ucl_N00760 VIMON 100
R_Ucl_Rcl3    Ucl_N50037  CL_CLAMP    0.01 TC=0,0
R_Ucl_Rcl2    N127440     Ucl_N01226   1   TC=0,0
G_G7          GND_FLOAT   CL_CLAMP   CLAW_CLAMP GND_FLOAT 1m
X_U3          VSENSE      GND_FLOAT  RNOISELESS PARAMS: R=1e6
G_G1          GND_FLOAT   N01819 INP_CMRR GND_FLOAT 56.2u
X_Ud4         N08964      INN3       d_ideal
X_U5          GND_FLOAT   P0Z        RNOISELESS PARAMS: R=1e6
G_G5          GND_FLOAT   P0ZP1  P0Z GND_FLOAT 1u
R_R3          GND_FLOAT   N127440    1G TC=0,0
X_U2          OVER_CLAMP  GND_FLOAT  RNOISELESS PARAMS: R=663.1
X_U8          CL_CLAMP   GND_FLOAT   RNOISELESS PARAMS: R=1e3
X_U6          P0ZP1      GND_FLOAT   RNOISELESS PARAMS: R=1e6
R_Uz_Rf1      Uz_N36964  Uz_VZO_1    10e6 TC=0,0
X_Uz_S2       N107583    GND_FLOAT   Uz_N45507 Uz_VZO_3 Zout_Uz_S2
R_Uz_Rg1      GND_FLOAT  Uz_N36964   10e6 TC=0,0
R_Uz_Rg2      Uz_VZO_2   Uz_N37614   1e6  TC=0,0
X_Uz_S1       N107583    GND_FLOAT   Uz_N45387 Uz_VZO_3 Zout_Uz_S1
R_Uz_Ra       Uz_N45387  Uz_VZO_4    10 TC=0,0
E_Uz_E1       Uz_VZO_2   GND_FLOAT   Uz_VZO_1 Uz_VZO_4 -1
R_Uz_Rm       Uz_VZO_3   Uz_VZO_4    10 TC=0,0
X_Uz_Uamp1    VCLP       Uz_N36964   Uz_VZO_1 GND_FLOAT VCVS_LIMIT PARAMS:
+    GAIN=1e6 VPOS=6e4 VNEG=-6e4
R_Uz_Rf2      Uz_N37614  Uz_VZO_3    1e6 TC=0,0
X_Uz_H1       Uz_VZO_4   OUT VIMON   GND_FLOAT Zout_Uz_H1
R_Uz_Rb       Uz_N45507  Uz_VZO_4    10 TC=0,0
X_Uz_Uamp2    GND_FLOAT  Uz_N37614   Uz_VZO_3 GND_FLOAT VCVS_LIMIT PARAMS:
V_V1          VCC        N08751      1.94Vdc
C_Cinp        GND_FLOAT  INP1  200f  TC=0,0
X_Ud1         INP_CMRR   N08751      d_ideal
C_Cc1         P0ZP1      GND_FLOAT   6f  TC=0,0
X_U12         INP1       INP2        vnse
X_U4          N90758 GND_FLOAT GND_FLOAT OVER_CLAMP VCCS_LIMIT PARAMS:
+  GAIN=15.1e-3 IPOS=0.1 INEG=-0.1
.ends TL972
.SUBCKT HPA_PD_Sgnl  CP  CN  DIS  VP  VN  VCC VEE PARAMS:  GAIN = 1
EVCVS  VP  VN  VALUE = {IF(V(DIS,VEE) >= 1.4,V(CP,CN)*GAIN,0)}
.ENDS HPA_PD_Sgnl
.subckt d_ideal a c
d1 a c dnom
.model dnom d
+ tt=1e-011
+ cjo=1e-018
+ is=1e-016
+ rs=0.001
.ends d_ideal
.SUBCKT HPA_PD_I VCC VEE PD Vimon AGND Ninp Ninn PARAMS: Vth = 1.4 Imax = 2e-3
+ Imin = 3n
+       IIBP= 200n  IIBN= 210n
GBIAS     VCC  VEE    VALUE = {IF(V(PD,VEE) >= 1.4,Imax,Imin)}
Ebuf      VDD  0      VCC  0   1
Ginp      VDD  Ninp   VALUE = {IF(V(PD,VEE) >= 1.4,IIBP,0)}
Ginn      VDD  Ninn   VALUE = {IF(V(PD,VEE) >= 1.4,IIBN,0)}
.ENDS
*Voltage Controlled Source with Limits
.subckt VCCS_Limit VCP VCN IOUTP IOUTN PARAMS: Gain = 1.7e-3
+ Ipos = 0.100 Ineg = -0.165
G1 IOUTP IOUTN VALUE={LIMIT(Gain*V(VCP,VCN),Ipos,Ineg)}
.ends VCCS_Limit
.SUBCKT EPOLY2 1 2 3 4 7 8 PARAMS: Coeff1=0.5  Coeff2=0.5
*EINT 7 8 POLY(2) (1,2) (3,4) (0 Coeff1 Coeff2)
EINT 7 8 POLY(2) (1,2) (3,4) (0 0.5 0.5)
.ENDS EPOLY2
.subckt tran_iout vcc vee vimon agnd
sw4 net11 agnd vimon net19 sm1
sw1 net11 agnd vimon net10 sm2
r61 vimon net11 10
r59 net19 agnd  10e3
r58 net10 agnd  10e3
g8  vcc   agnd net19 agnd 1e-3
g7  vee   agnd net10 agnd 1e-3
c15 net11 agnd 10e-12
.model sm1 vswitch
+ ron=0.001
+ roff=1e+006
+ von=0.1
+ voff=-0.1
.model sm2 vswitch
+ ron=0.001
+ roff=1e+006
+ von=-0.1
+ voff=0.1
.ends tran_iout
.subckt VCVS_Limit VCP VCN VOUTP VOUTN PARAMS: Gain = -1
+ Vpos = 20m Vneg = -20m
E1 VOUTP VOUTN VALUE={LIMIT(Gain*V(VCP,VCN),Vpos,Vneg)}
.ends VCVS_Limit
.subckt rnoiseless a b PARAMS: R=1k
*H_H1 c b VH_H1 {R}
*VH_H1 a c 0
ERES a 3 VALUE = { I(VSENSE) * R }
Rdummy 30 3 1
VSENSE 30 b DC 0V
.ends
.SUBCKT EPOLY1 1 2 3 4  PARAMS: Coeff1=0.0  Coeff2=0.0
*For distortion purpose
*EINT 3 4 POLY(1) (1,2) (0 1 Coeff1 Coeff2)
EINT 3 4 POLY(1) (1,2) (0 1 0 0)
.ENDS EPOLY1
.subckt Zout_Uz_S2 1 2 3 4
S_Uz_S2         3 4 1 2 _Uz_S2
RS_Uz_S2         1 2 1G
.MODEL         _Uz_S2 VSWITCH Roff=10e6 Ron=1.0 Voff=0.1V Von=-0.1V
.ends Zout_Uz_S2
.subckt Zout_Uz_S1 1 2 3 4
S_Uz_S1         3 4 1 2 _Uz_S1
RS_Uz_S1         1 2 1G
.MODEL         _Uz_S1 VSWITCH Roff=10e6 Ron=1.0 Voff=-0.1V Von=0.1V
.ends Zout_Uz_S1
.subckt Zout_Uz_H1 1 2 3 4
H_Uz_H1         3 4 VH_Uz_H1 1e3
VH_Uz_H1         1 2 0V
.ends Zout_Uz_H1
.SUBCKT VNSE 1 2
* SET UP VNSE 1/F v [NV/RHZ]
* FREQ FOR 1/F VAL
* VNSE FB  -NV/RHZ FLATBAND
.PARAM NLF=41
.PARAM FLW=20
.PARAM NVR=3.5
* START CALC VALS
.PARAM GLF={PWR(FLW,0.25)*NLF/1164}
.PARAM RNV={1.184*PWR(NVR,2)}
.MODEL DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16
* END CALC VALS
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVN
D2 8 0 DVN
E1 3 6 7 8 {GLF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNV}
R5 5 0 {RNV}
R6 3 4 1E9
R7 4 0 1E9
E3 1 2 3 4 1
C1 1 0 1E-15
C2 2 0 1E-15
C3 1 2 1E-15
.ENDS VNSE
.END
    \$\begingroup\$ FYI, it usually helps to set RSHUNT = 1e9 and GMIN = 1e-9 or thereabouts. The various TOLs may also be of use. What is the op-amp model from? Matter of fact, could you show the simulation output code (.nsx)? \$\endgroup\$ Jul 20, 2022 at 16:54
    \$\begingroup\$ Where did you get the "op-amp" SPICE model? I haven't thought about it hard, but it's definitely not the usual way to model an op-amp. \$\endgroup\$
    – The Photon
    Jul 20, 2022 at 17:30
    \$\begingroup\$ It's ok to answer your own question (using and submitting via the answer box), and mark it as accepted (after 48 hours). Someone with the same problem that you had will be thankful. \$\endgroup\$ Jul 20, 2022 at 18:48
    \$\begingroup\$ The schematic you're showing does not represent the netlist. The schematic shows an opamp with 5 pins, while the netlist lists only one subcircuit, XU1A, named ASW, which only has 3 pins. Not lastly, as the others have mentioned, that's not an opamp model, it's probably some analog inverter (if V(NCTRL)>0.5 then it's the normal input, otherwise it's the negative of it). And now you say it works with enough power supply, which further means that ASW is not what you're using. I'm sorry, but you did not deserve the upvotes for the sloppyness and confusion. \$\endgroup\$ Jul 21, 2022 at 8:50
    \$\begingroup\$ I see the updated schematic and sim code ("deck" as they call it), are you still getting errors (Messages image was not updated)? \$\endgroup\$ Jul 21, 2022 at 18:16
Holey moley! That's not an amp model, that's an affront to humanity! I don't know where you got it from, but uh yeah, that's likely a problem.
Downloading the model: https://www.ti.com/lit/zip/slom243 I see TL972.lib has a TL972 subcircuit, which seems promising. (Hint: rename to *.ckt, Altium's default subcircuit file extension.) Hmm, lots of sub-subcircuits, hopefully that's not too awful...
Oh. I see what's gone wrong. There is an ASW in here, and it is as disgusting as quoted, and well, for one thing you picked just completely the wrong part.
Heh, did ASW just show first on the list, and you assumed that was the only model in the file..? A simple mistake, use the TL972 subcircuit instead.
Hrm, but all these extra bits, aren't looking very encouraging...
So, this is a PSPICE model. Altium has some PSPICE compatibility, so it may work, but it has poorer stability, and all those IF()s are likely to crash and burn. If it doesn't, it's unlikely any combination of settings will make it behave; you can try high and low timestep (initial and max), much looser ABSTOL and CHGTOL (up to 1e-6 or so?), VNTOL (1m?), RELTOL (10m, even 100m just to be totally gross?) and TRTOL (20? 60?). And you'll probably be stuck with TRAP integration, no smooth GEAR (INTORD >= 2)
Explanatory aside:
That IF() even exists, is bizarre; SPICE depends on continuous functions, to be able to take derivatives of them, and either linearize the system for AC steady state analysis, or integrate step by step to produce a transient analysis. There is no general definition for which IF() is guaranteed to have continuity; at best (and, I think originally this was a requirement of its use?), the two clauses must match at the decision point, thus avoiding a discontinuity, up to however many derivatives are matched/needed.
As far as I know, PSPICE assumes it's... I don't know, some kind of ramp function between extremes, maybe? Plus many other hacks that generally improve stability despite such ill-formed functions.
To be fair, simulators have moved on quite a bit since the 80s; but Altium unfortunately is still* stuck back in history with a mostly-stock XSPICE (1992!) backend.
*They have supposedly made improvements recently, though I don't have AD21+ to check for myself. It may also just be window dressing; I know they updated a lot of interface and dialog stuff, but no idea about the core simulator.
  • \$\begingroup\$ I fully agree with your first paragraph. \$\endgroup\$ Jul 20, 2022 at 21:39
  • \$\begingroup\$ I made a hasty judgement because it was the end of the day for me, but OP's schematic does not represent the netlist. \$\endgroup\$ Jul 21, 2022 at 8:51
  • \$\begingroup\$ Yes, I realized that too. As I said, I'm new to Altium so when I tried to import the model, I didn't actually realize that I skipped a step in selecting the right model. Sorry about that, and I appreciate the detailed info! I have selected the right model, and netlist looks correct now. \$\endgroup\$ Jul 21, 2022 at 16:11
