I have designed a project that includes a TP4056 with DW01 protection ic and porwer sharing feature. Now I want to include a fuel gauge and the only one I have found is MAX17048 I have readed the MAX17048 datasheet ant it shows you should connect GND and CTG pins to GND but I have 2 different "grounds" one the BAT- pin and the other one is the "real" common GND.
TP4056 Circuit
I don't know which one should I use because if I use the BAT- then may be a problem when I interface it with the uC because ground isn't the same, but it I connect it to GND I don't know if it will measure the real battery level. Which one should I use and why (if possible)?
MAX 17048 application
Thanks in advance for your help!
PS: I'm sorry if my english is'nt good enough I have done my best.
  • \$\begingroup\$ The MAX17048's application circuit suggests you to where to connect already. The block named "PROTECTION" basically consists of DW01 and the back-to-back NMOSs. \$\endgroup\$ Jul 21, 2022 at 17:50
  • \$\begingroup\$ @RoharKiliç Thanks for your answer! I have seen the protection block but I dont really know which is the protection pin it refers because DW01 is connected to GND in the pin 2 and B- in the pin 6. If i connect it MAX17048 GND to DW01 pin 2 then I'm just shorting BAT- and system GND but if I connect MAX17048 to DW01 pin 6 then MAX17048 ground and system ground are not the same and It can cause problems when interfacing the uC. \$\endgroup\$
    – Emirikol
    Jul 21, 2022 at 18:11
The real gnd is where you need and define 0V, which for logic is the MAX17048 and the uC logic interface.
The 5V connections +/- must be isolated from ground then the SoC measurements are differential on the battery -ve when connected to ground=0V.
If this uC is working during charging, and there is common mode RF noise from the charger 5Vin then a small RF cap may help from OUT- to GND.
The problem with connecting B- and OUT- is when drawing power OUT and charging at the same time, the charger is also sensing OUT power. If that power happens to be more than the cutoff current threshold (? 5% of CC) during CV mode at 4.2V then it may never cutoff and degrade the battery. So by adding a separate current sense resistor charging while using battery power can be used. So the I hope this is correct.
  • \$\begingroup\$ Thanks for your answer. So I must connect MAX GND to System GND isn't it? As far as I know B- and GND is the same unless DW01 disconnect it to avoid discharge right? \$\endgroup\$
    – Emirikol
    Jul 21, 2022 at 18:15
  • \$\begingroup\$ Yes but how are you intending to connect USB and uC with 5V for both circuits? \$\endgroup\$ Jul 21, 2022 at 18:33
  • \$\begingroup\$ What do you mean? I use a boost to get 5v from battery and i use USB power when it's charging. \$\endgroup\$
    – Emirikol
    Jul 21, 2022 at 18:39
  • \$\begingroup\$ I meant is your uC gnd also communicating to the same device with USB providing 5V \$\endgroup\$ Jul 21, 2022 at 18:55
