I need to make a powerful solenoid lock using 220 V AC.
Let say I will use 21 gauge wire and get a length of 24 Ω. This will draw 9 A from the 220 V, so 1980 W.
This will be great force electromagnetic but the problem is this: the 21 gauge can only withstand 1.2 A maximum; to avoid getting maximum current I need to make the resistance 183 Ω, which means about 3 km of wire!
And this will cause less force because the current now is 1.2 A; calculating other gauges in the same manner will result in this too-long length.
Is my calculation wrong, or is the reality not like the theory, or what?
How to make a solenoid coil that can connect to 220 V safely, and the gauge?
