So I understand that when you are correcting power factor you are decreasing the system's reactive power. This is usually done by adding capacitors, which also reduce the total current supplied by the source. Still, I don't get why voltage losses are decreased, for example, when you have a three-phase system with line impedances between loads.
So why does this happen? Why is voltage increased? Thanks.
Edit: apparently voltage losses are is actually increased, and power losses are decreased. Why?
