Using your voltage crossover distortion you can compute the impedance of the DC resistance of R and the reactive impedance of L and get a ratio when it is almost 90 degrees. The crossover is simply the lagging inductor current when the emitter followers go high impedance between +/-0.7V. This gets shifted because diodes will rectify and crossover at 0 current and not output 0 V crossover. Since it is not quite 90 deg, some reduction is due to lossy winding resistance at DC called DCR in datasheets.
When neglecting to use output feedback, this circuit experiences 1.2V crossover distortion.
- on a resistive load with a flat line during crossover voiding the signal for 1.2Vpp during the crossover.
- on an inductive load the current is rectified 90 degrees later at the peaks of the sine showing a 1.2V transition due to the current dropout of both base emitters.
For a better design, one uses negative feedback from the emitter output. One must consider that any DC offset will produce a steady state Vo/DCR=I inductor current. An excessive offset may possibly saturate the inductor. There may also be current gain limitations if there is DC offset and lots of heat in the active driver, but with careful design, this can drive a speaker.
Does this now look like a Class AB driver?
To find current limitations, try a squarewave.
