-1
I'm trying to read capacitor voltage over ESP8266 A0 pin. Positive capacitor output is always conected to A0. Negative is connected to ESP8266 via a BC547 transistor to prevent capacitor discharge. Transistor acts as a switch - it connects capacitor negative to ESP GND for voltage reading only when I send a high signal to the base of this NPN transistor. Voltage reading over A0 works fine, but I get a reading even when the transistor is off. What could be the issue ?enter image description here
    \$\begingroup\$ As drawn, the capacitor is always connected to GND and it is the ESP's ground pin that's being switched... \$\endgroup\$ Jul 26, 2022 at 12:21
  • \$\begingroup\$ Yes, I'm switching ESP GND to capacitor negative via transistor. I want to prevent A0 discharging capacitor when it is not performing reading. Is this correct way to perform this ? \$\endgroup\$
    – Marc
    Jul 26, 2022 at 12:38
  • \$\begingroup\$ Draw the rest of the circuit. Where does "PIR OUT 3.3V" come from and where is it's ground connected? \$\endgroup\$
    – brhans
    Jul 26, 2022 at 13:56
  • \$\begingroup\$ PIR 3.3v is pir sensor output. I'm using capacitor to store PIR value (if PIR was high). Pir GND is connected to capacitor negative. \$\endgroup\$
    – Marc
    Jul 26, 2022 at 15:21
    \$\begingroup\$ If you only need to know if the PIR was triggered during the hour the ESP sleeps (and not how many times it was triggered) you could use a interrupt to wake up on PIR trigger, and then disable the wake-up on PIR trigger before going to sleep again. So it'll only wake up once on the first trigger... \$\endgroup\$ Jul 29, 2022 at 7:15
Very low current analog 1 bit memory
You can isolate the capacitor using a MOSFT as switch. If you want to check the capacitor voltage, you activate the MCU output WANT_READ and immediately take an ADC measurement. This way there is no current consumption via R1 during sleep mode.
The voltage at MCU_ADC can be lower than the capacitor voltage because it will not rise above VCC - Vthr (the threshold voltage of the MOSFET). But since the purpose of this circuit is only a kind of event memory, this should not be important as long as a FET with low threshold is used.
Finally the capacitor fully discharges via R1 and a new cycle can start after WANT_READ is low again.
This circuit is not free from leakage currents but will hold the information for some hours.
Some MCUs have a very high dc input resistance at their ADC inputs (e.g. 100 Mohm ATmega88-328 series) and the circuit would not be needed at all for 1 hour info hold time.
Edit:
Alternative solution with BJT
  • \$\begingroup\$ Thank you for this schematic. Is it possible to use 3.3v logic level mosfet like IRLZ44N since I can obtain BSS138 only in SMD version ? Or perhaps an opto coupler ? \$\endgroup\$
    – Marc
    Aug 8, 2022 at 21:17
  • \$\begingroup\$ @Marc IRLZ44N is not an option, but an opto coupler is a good idea. I just don't know the typical leakage current of them. An NPN with 50 kohm base resistor may also work. \$\endgroup\$
    – Jens
    Aug 8, 2022 at 21:27
  • \$\begingroup\$ could you help me with schematic using PC817 optocoupler ? I tried to connect A0 pin to PIN4 (colector) of opto and pin 4 (emiter) to output of capacitor. But I get consant A0 reading despite of opto state (I'm controling opto using digital output). PIR and ESP8266 are connected to same battery. Could this be the issue ? \$\endgroup\$
    – Marc
    Aug 10, 2022 at 18:51
  • \$\begingroup\$ Its just the other way round: collector to the capacitor, emitter to R1, because the voltage at C1 is more positive (in case of an event) \$\endgroup\$
    – Jens
    Aug 10, 2022 at 20:43
  • \$\begingroup\$ The opto coupler needs 18µs time to conduct, so you have to wait that before reading the ADC (delayMicoseconds) \$\endgroup\$
    – Jens
    Aug 10, 2022 at 20:48
