35
I'm struggling to get an I2C master to communicate reliably with a slave, because there's also an MCP23017 port-expander on the same bus. The MCP23017 seems to detect - and ACK! - its address, even when that bit pattern appears coincidentally in the midst of other devices' conversations. When it does the spurious ACK, it crushes the current data bit to '0' which corrupts the received message.
I can't find any published errata on this. Is this real, or have I messed up?
This seems really serious. I'm finding there are certain messages that simply cannot be sent correctly to a different slave, because they look valid but contain spurious zero bits.
Evidence:
An an experiment, we just hooked an Arduino up to the MCP23017 using I2C, and wrote some code to bit-bang the I2C as though to talk to a different (non-existent) device. Halfway through, the MCP23017 leaps in and corrupts the comms with its spurious ACK.
Notes:
  • For the experiment, the I2C bus is just implemented using the Arduino's digital pins 4 (SDA) and 5 (SCL), with the Arduino's internal pull-ups. Not perfect, I know, but it happily talks to the MCP23017 when we tried it.
  • We added a 10k resistor to the MCP23017's SDA, so that when it interferes with the bus, it's a visibly weaker signal on the scope.
  • We ran a control experiment to ensure that the setup could correctly talk to the MCP23017, which it could - all good. Then we modified the code to pretend to talk to a different device, and the MCP23017 butted in with its spurious ACK despite not being addressed.
  • It's quite an old MCP23017, from 2005.
Here's the code - you can drop this into a .ino file and just upload it. It adds small delays to make the scope traces intelligible.
enum I2cResult {
  OK,
  WRONG_BIT,
  NACK,
  WRONG_BIT_NACK
void sdaLow(){
  pinMode(4, OUTPUT);
  digitalWrite(4, LOW); // just make sure that no matter what pinMode does, we get it right...
void sdaHigh(){
  pinMode(4, INPUT_PULLUP);
bool isSdaHigh(){
  return digitalRead(4);
void sclLow(){
  pinMode(5, OUTPUT);
  digitalWrite(5, LOW);
void sclHigh(){
  pinMode(5, INPUT_PULLUP);
bool isSclHigh(){
  return digitalRead(5);
void startBit(){
  delayMicroseconds(10);
  if(isSdaHigh()){
    sclHigh();
    delayMicroseconds(20);
    sdaLow();
    sclLow();
  } else {
    sclLow();
    sdaHigh();
    sclHigh();
    sdaLow();
    sclLow();
void stopBit(){
  if(isSdaHigh()){
    sclLow();
    sdaLow();
    sclHigh();
    sdaHigh();
  } else {
    sclHigh();
    sdaHigh();
//Sends a 1 or 0 based on level - false gives 0, true gives 1.
//returns true if the level on the pin matched the written level
bool sendBit(bool level){
  if (level){
    sdaHigh();
  } else {
    sdaLow();
  delayMicroseconds(25);
  sclHigh();
  bool v = isSdaHigh();
  sclLow();
  return v == level;
I2cResult sendByte(uint8_t b){
  I2cResult result = OK;
  for(uint8_t i = 0; i < 8; i++){
    if (i == 4){
      delayMicroseconds(50); // adds space on scope for readability
    bool v = (b & (1<<(7-i)));
    if(!sendBit(v)){
      result = WRONG_BIT;
  if(sendBit(true)){
    if(result == WRONG_BIT){
      result = WRONG_BIT_NACK;
    }else{
      result = NACK;
  return result;
//This sends a byte and acks it (simulating a slave receiving the data).
I2cResult sendByteAck(uint8_t b) {
  for (uint8_t i = 0; i < 8; i++) {
    if (i == 4){
    if (!sendBit(v)){
      result = WRONG_BIT;
  sendBit(false);
  return result;
void setup() {
  Serial.begin(9600);
  Serial.println("hello!");
  delay(100);
// The MCP23017 is wired to use address 0100 000.
// We then pretend to talk to another device - on address 1100 001, and send it the byte 1000 0001
// This triggers the bug, as, including ack bits, the bus has the following data:
//  start|Address|ACK|  Data |Ack|stop
//     S 1100 0010 0 1000 0001 0  P
// with the data the expander sees highlighted (+--+ for the address nibbles, ^ for the ack)
// the expander then writes 0 over the 1 at the end.
void loop() {
  startBit();
  sendByteAck(0xC2);
  delayMicroseconds(150); // adds space on scope for readability
  Serial.println(sendByteAck(0x81));
  stopBit();
  delay(10000);
Here's the hardware, on a bread-board: breadboard with Arduino Nano and MCP23017
Here are the scope traces showing the issue - yellow is Clock, blue is Data. This image shows the whole two-byte message: Scope trace showing whole message, with spurious ACK
This image below zooms in on the second byte. Note the weakened '0' on the blue data line, visible once the Arduino stops asserting SDA=0, where the MCP23017 is asserting its ACK after apparently seeing a phantom 0100 000W. Scope trace zoomed in on bad second byte
  • 11
    \$\begingroup\$ Ok, I'm gonna answer this myself. Sorry. I spent the morning collecting evidence, and writing this nice question. Then I found the relevant errata. Posting question in case it helps anyone. \$\endgroup\$
    – SusanW
    Jul 26, 2022 at 13:56
  • 11
    \$\begingroup\$ No need to apologize; I think this is a stellar example of a self-answered question, with enough details and keywords to be searchable and useful to future users. \$\endgroup\$
    – nanofarad
    Jul 26, 2022 at 14:18
  • 9
    \$\begingroup\$ @nanofarad Thanks! :-) A lot of WTFs went into this - mysterious but deterministic data corruption injected by a component we weren't even looking at... caused by a gremlin from 17 years ago! \$\endgroup\$
    – SusanW
    Jul 26, 2022 at 14:27
It's a known problem with that early revision of the chip.
Newer revisions are fixed. My ones are date-coded 0522 (I guess week 22 of 2005, which is about when we got them, back in the days when you could buy chips with same-year delivery!), and they were fixed from 0543 onwards. Pretty unlucky, really - I expect there's probably a moral here somewhere.
For details, see: Microchip's errata sheet
Specific relevant text:
All of the issues listed here will be addressed in future revisions of the MCP23017 silicon.
  1. Module: I2C™ Module
In silicon revisions A0 and prior:
The I2C may detect its slave address (OPCODE) at the wrong time in a data transfer and acknowledge (ACK) its perceived OPCODE. During normal operations, the MCP23017 expects the byte immediately following a Start bit to be an OPCODE.
When the device is not addressed, it should remain silent and not interfere with the bus. However, the device continues to monitor the bus and checks for an address match every 8 bits and acknowledges (ACKs) if a match is detected.
While the device checks for a match every 8 bits, every data byte transfer on the bus is 9 bits long, causing the device’s matching routine to get out of phase with the bus. Therefore, the false ACK could occur in the data field as well as the ack field.
Work around
The issue was addressed and no longer appears in silicon revision A1. See Appendix B: “Silicon Revision History” to determine how to identify the silicon revisions.
As long as there are no other devices on the bus, or the data on the bus is known (and does not cause a false match), the issue will not appear.
A hardware work around may be used which disables the clock input to the MCP23017 when it is not addressed.
Date Codes that pertain to this issue:
• Date code 0542 and earlier have the issue.
• Date code 0543 and later do not have the issue.
  • 14
    \$\begingroup\$ Congrats: that's a horrible bug to troubleshoot (and to bug-fix). Thanks for sharing. \$\endgroup\$
    – glen_geek
    Jul 26, 2022 at 14:45
