Here is my whole diagram. There is no output while also clock is ticking...
I think there is a problem with the counter, but I can't figure it out.
I use rising-edge flipflops.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityHere is my whole diagram. There is no output while also clock is ticking...
If those are positive edge triggered flip-flops then you need to come off the Q-bar outputs into the next clock inputs for an up counter. Come off the Q outputs as shown in your diagram if the flip-flops are negative edge triggered. If the flip-flops shown are positive edge triggered then the counter will count down from 0 direct to 15 and immediately reset back to 0.
