I wonder what is the minimal latency of a digital-to-analog converter (DAC). What is the minimal clock cycle the DAC takes between the arrival of the digital signal to the output of analog signal?
\$\begingroup\$ It depends on how rich you are. I am a poor hobbyist. My favourite DAC/ADC module is this: aliexpress.com/w/wholesale-pcf8591.html \$\endgroup\$– tlfong01Jul 30 at 3:51
\$\begingroup\$ And conversion rate is about 10kHz: PCF8591 8-bit A/D and D/A converter (I2C, Conversio frequncy ~= 11kHz) - NXP 2013 nxp.com/docs/en/data-sheet/PCF8591.pdf \$\endgroup\$– tlfong01Jul 30 at 3:57
1\$\begingroup\$ It doesn't have to take any clock cycles at all. If you make the DAC out of a chain of resistors, how could it? \$\endgroup\$– user_1818839Jul 30 at 10:57
\$\begingroup\$ After the arrival of DAC data, you have a settling time of 90us for the PCF8591. Latency is generally used in systems that "delays" data samples while converting. Latency can also be defined with N samples ... that is to say that the results of the actual conversions will be "delayed" by N samples (example N =1). \$\endgroup\$– Antonio51Jul 30 at 12:03
\$\begingroup\$ @tlfong01, if budget is unlimited? \$\endgroup\$– RickyimJul 31 at 11:52
1 Answer
I used an AD9742 12-bit DAC in a recent project. No doubt far from the fastest, but fast enough to synthesize some clean low MHz signals when fed fast digital data.
Settling time is ~11ns. Something like $12 in 100's, so not crazy expensive.
When you develop your specific requirements you can do parametric searches at the suppliers such as analog.com, ti.com etc. and distributors and narrow down your search.
