I understand how servos and steppers are different (or at least I think I do), but I noticed several things that I don't understand.
  1. Most steppers seem to come in hard metal cases while servos are made with plastic cases, why is that?
  2. Servos always come with a set of arms to connect to the shaft while steppers don't. It could also be useful to have such arms attached to the shaft of a stepper, no?
  3. When looking for 3D-printed gearboxes, I can find many for steppers, but I cannot find any for servos (though I can find metal gearboxes for very big servos), why is that?
  • \$\begingroup\$ what do you understand about the differences between a stepper and a servo? ... \$\endgroup\$
    – jsotola
    Jul 30, 2022 at 20:55
  • \$\begingroup\$ Servos are closed loop and have high speed torque while steppers are generally open-loop and have low speed torque? But this does not help me figure out my questions \$\endgroup\$
    – vital
    Jul 30, 2022 at 21:01
  • \$\begingroup\$ probably because your questions are about the physical properties of the two devices ... a stepping motor is a motor, so it has motor construction ... a hobby servo contains a motor and a gearbox and control circuit ... hobby servo can be commanded to turn to a specific angle, that makes it desirable for use in hobby models ... a stepper can be commanded to move one step ... a hobby servo has a limited range of motion ... a stepper can continuously step in a one direction, if needed ... a hobhy servo comes with arms that are useful in moving things like a throttle or steering \$\endgroup\$
    – jsotola
    Jul 30, 2022 at 22:15
"Servo" has various meanings. A servo motor will look very like a stepper motor but you might be able to see an encoder attached to the back end.
Figure 1. A servo actuator after a savage attack by an unidentified animal. Image source: Sparkfun. The linked article would be worth a read - although I note that they refer to this as a servo "motor". (It probably is in the dictionary sense of a motor.)
What you are calling a "servo" is probably a servo actuator for a model such as an RC airplane. These don't have a true servo motor but have a small DC motor, gearbox, a position sensing potentiometer on the output shaft and some electronics to run the motor until the actual position matches the commanded position.
See above. The DC motor is inside the plastic case.
  1. Servos always come with a set of arms to connect to the shaft while steppers don't. It could also be useful to have such arms attached to the shaft of a stepper, no?
That's definitely a servo actuator. A stepper version would also require a gearbox and feedback. The electronics would be more complex. There's no market for it.
  1. When looking for 3D-printed gearboxes, I can find many for steppers, but I cannot find any for servos (though I can find metal gearboxes for very big servos), why is that?
True servo motors will probably run at much higher speeds than the steppers. I'd say you're looking at hobby grade parts and the hobbyists will use steppers for ease of control and low cost.
This is a Servo Motor:
This is a Hobby Plastic Servo Actuator:
This is an Industrial Linear Servo Actuator:
Servo motors used where reliability and resilience matters are robust, metal-cased parts. Same goes for actuators built using them.
The hobby servo actuator stuff is plastic because it needs to be cheap and light-weight for typical radio-control applications where the plastic design originated. Inside is a metal-cased DC motor anyway, you just don't see it.
You essentially googled using hobby search terms and got hobby results...
