I've been wondering for the longest time about how a monopole antenna (like the one in a typical FM radio) can work without offering a return path for current.
I have a hypothesis, and I'd really appreciate if the experts here could please either validate it, or contravene it and offer the correct explanation instead (I'm particularly interested in a conceptual explanation rather than a mathematical development).
My hypothesis: current in fact has a loop through the earth because there's an "air capacitor" between the circuit and the earth (the metal of a vehicle can serve the same purpose as the earth if the antenna is inside an airplane for example). Please see image below.
Is this how it works? If not, could a conceptual explanation of how the circuit can work ostensibly without a closed loop (a current return path)? From Kirchhoff's laws, I understand that current has to travel in loops.
Especially if the hypothesis is wrong, if a conceptual explanation could please be provided how the circuit can work without a closed loop for current to flow through.
Note on the image: I know that at that frequency the antenna is also a transmission line. I assume that the characteristic impedance of the line is 75 Ω, so since there's a 75 Ω resistor underneath, the entire voltage will get absorbed by the 75 Ω resistor, and the antenna will behave as a nice short circuit (won't absorb / reflect any voltage).
Edit:
I've added a transmitter circuit. Question: Current doesn't go between the transmitter and receiver?
Rather voltage entering into the transmitter antenna becomes the energy of the EM wave. The EM wave in turns excites voltage at the receiver. But it's energy / voltage transmission, while the currents of both transmitter and receiver - whether conduction or displacement - are independent. Would that be correct?
Edit: let me summarise my understanding of the answer (comments are appreciated).
There are two kinds of current:
A. Conduction current as through any resistor.
B. Displacement current - when current "flows" through empty space, like between the plates of a capacitor.
Current literally flows down the 75 Ω resistor in mode A.
Then, from the bottom of the 75 Ω resistor and back to the top of the antenna, current "flows" in mode B (in fact current through any capacitor "flows" in mode B).
Hence a capacitor is a good model for the gap between the bottom of the 75 Ω resistor and the top of the monopole antenna.
But as has been pointef out it's not as simple as a capacitor, and there are some complexities involved (as Tim said: "not quite the same, as the curvature of those lines, and the exact magnitude and phase, will all depend on a fields solution, for the D-field around the whole element. But to the extent we can ignore those effects, and especially for 1/4λ mode and below, this is good enough").
