I am interested in using the following mixer by mini-circuits: RMS25-MH+. In the datasheet it is specified that the required LO drive power is 13dBm.
As i understand it double balanced mixers use diodes and so are non-linear devices. I only have available a signal generator that I can set the peak voltage to. My question is how can I determine the required LO input voltage. Do I assume that the input impedance looking into the LO port is 50 ohms and calculate from there?
