I want to amplify an output signal from a sensor. The sensor is made of three inductors which are coupled. One primary inductor with 25uH and two secondary inductors wired in the opposite direction with 3uH and 1uH. For the amplification I chose an instrumentation configuration which will be followed by a fully-differential op-amp. The amplifier is configured as a lowpass filter with two poles and a zero to even out the transfer function. The amplifier consists of two LT6230-10 op-amps. The transfer function looks like this and already gives a hint for a possible oscillation at about 40 MHz:
The output in time domain when exciting the sensor with a 2 MHz 1Vpp sine looks like this:
I thought this might be an issue caused by the feedback network with several capacitors. But when I simulated the circuit without the capacitors, there was still oscillation. Erasing the parasitics of the inductors doesn't change anything. I erased the center tap of the inductors, grounded inductor L8 and wired only one LT6230 as a buffer. It still oscillated. The oscillation stopped when I wired one LT6230 as a non-inverting amplifier with a gain of about 10.
I can't make the circuit work in the in-amp configuration though. No matter what gain I set without the feedback capacitors, it oscillates. This circuit or the op-amp seems to have trouble with the inductance at the op amp input. As an alternative I tried the OPA837, which had similar problems.
Can anyone tell me what is going on here and what could be done to stop the oscillations in the in-amp configuration?
L8
? \$\endgroup\$
