I am a Student of Electronic Engineering from Seville´s University.
This summer I am trying to make an egg incubator using an Arduino but I am doing the footprint for making the PCB on Altium.
The problem that I have is that when I go to "Design" and I update the PCB, I get a lot of errors (shown in the images).
I have revised all pins and still I have the "pin error" and with the other error of "Failed to add class member: component...". I have checked the library and the pins and it is OK.
I don´t know if I have made the sketch wrong, but I would like if someone would help me because I have one month like this.
I would like it if someone can help or give me the solution or I don´t know but I am tired of read a lot of articles and still the same...
Hi guys!
I have read all your comments and thanks for all.
But my problem is in my "arduino piece" because when I go to "Design" and "Update PCB in Schematic" I go to validates changes. then I have the "failed to add a class member" but i go to "execute changes" and everything is fixed . So when I look at the Schematic Its seem that everythig is conected but minus arduino and still I´ve got "pin failure" (I´ve checked arduino a few times).
I have update the photos.
    \$\begingroup\$ Normally I'd spend some time editing your question and helping to answer, but here I'm going to write why I down-voted. First, this isn't a forum, so you do NOT ask for private messaging links or email addresses. Second, if you can't be bothered to capitalize and spell correctly, it just sends the message that you aren't that serious about it. Which is why I'm commenting instead of going to extra effort for free. \$\endgroup\$
    – JYelton
    Commented Aug 2, 2022 at 22:34
  • \$\begingroup\$ Ok my fault its my first time to be here. I would like to say Sorry and it wont append again but I dont know what to do or where i can go... because i have asked my teachers and they dont help me to... :c \$\endgroup\$
    – Niza
    Commented Aug 2, 2022 at 23:09
  • \$\begingroup\$ You can edit your question. Just click edit, and spend a moment to clean it up. There are lots of Altium users here and many of us are happy to help when it seems worthwhile. \$\endgroup\$
    – JYelton
    Commented Aug 2, 2022 at 23:17
  • \$\begingroup\$ I've gone ahead and edited your question, provided an answer, and removed the downvote. Please take a moment to review what I've edited and then check out the site's help page to learn more about how the site works. \$\endgroup\$
    – JYelton
    Commented Aug 3, 2022 at 0:24
  • \$\begingroup\$ Secret trick.... The errors don't need stop you. If you look at your copper and you "know" it's connected right, you don't need to worry about the errors. \$\endgroup\$
    – Kyle B
    Commented Aug 3, 2022 at 4:11
Before trying to create or update a PCB, you should Validate your schematic. (Project > Validate PCB Project). This is also shown when you try to update the PCB. Errors can prevent the update process from working correctly.
The Messages panel (View > Panels > Messages) will list any errors and warnings that the schematic has based on the Error Reporting configuration under project options (Project > Project Options > Error Reporting tab).
The visible errors in your image are:
  • Unknown pin
  • Failed to add class member (under add component class)
Unknown pin
The unknown pins correspond to components which you've assigned the designators TERMOS and RELOJ1.
(Note that designators in schematics are commonly assigned using just one or two characters followed by a number. For integrated circuits or "chips" these are usually U. Instead of TERMOS, that component might be better designated U1. Connectors and jacks might be assigned CN or J, so instead of RELOJ1 it would just be J1.)
Do your symbols — the components in a schematic — have valid footprints associated with them? It appears that you have a symbol to which you've connected wires, but when you try to publish to the PCB, it can't find the appropriate pads that would be associated with its footprint. You should read up on how to create footprints.
When you say "I have checked the library and the pins and it is ok." what do you mean? Did your library compile without any errors? Have you verified the symbol pins all correspond to footprint pins? Refer to the link above (re: how to create footprints) if not.
The failure to add class members is a secondary effect of not having working footprints. When Altium adds a component footprint to a PCB, it (by default) also adds that PCB component to a component or room class based on the schematic sheet it is on. If the footprint were working, this error would likely disappear. Nevertheless, you may want to review how class generation works.
Other possible validation errors
Based on your images, I'll list some other potential issues:
Are you using a standard grid for your schematic editing? You have little kinks and bends in your wires which suggests you're having some problems here. Symbol pins and wires on the schematic can be difficult to connect properly if the symbol uses one grid pitch and the schematic editor uses another. It is highly recommended (but not required) to use 2.54 mm (100 mil) grid spacing for both. It's possible to have wires that look connected but actually aren't, which can result in errors during schematic validation.
Previous questions/answers related to this:
The Arduino in the center of your schematic still has a wildcard placeholder for its designator (*). As above, you should assign it a designator that you can use to refer to it, as well as avoid schematic annotation errors. You can maintain all the designators manually, or use the annotation tools.
Finally, there are lots of good resources on the web, but you may have missed them. In particular, you should know about and use:
There are also great users who've posted countless hours of content that often teach a great deal about PCB design and Altium in particular.
As you can see, there's a great deal of information that goes into answering your question. If you have further questions, you should use one of the resources above, or ask a new question. (Don't add a comment below to ask a new question.) Hopefully the information I've provided will help you narrow the problem down, and if you continue to have errors, you can post a new question that is specific to an error. Being specific is how to get definitive, useful answers.
