Why am I not getting the expected gain out of my op-amp?
I m using a 16-pin TI OPA4322SAIPW op-amp with a Advanced Photonix 019-141-411-R photodiode and this circuit:
where Rin is 1.8 kΩ and Rf is 27 kΩ. My Vin measured across the photodiode is ~0.14 V in ambient lighting conditions. I have also connected my op-amp to 3.3 V from a Pi Pico and to ground. I would expect to get Vout = -(27/1.8)·0.14 V = -2.1 V. However, when I read the output using a Raspberry Pi Pico ADC pin, I get 0.34 V. Is there something off with my op-amp here? I also replaced the op-amp with a fresh one and got the same behavior.
My goal is to get around 3.3 V out, but no matter what I do, I can't seem to get above 1 V out of my op-amp. Am I missing something?
Update: I've got everything working now, The issue was that my photodiode was a reverse bias diode. I got it working using the circuit from this answer although Spehro's answer to this would have worked for any forward bias diode.
    \$\begingroup\$ Please show all connections and pin numbers. \$\endgroup\$
    – Mattman944
    Aug 3, 2022 at 1:23
  • \$\begingroup\$ I would first realize that a photodiode is best thought of as a light dependent current source, not a voltage source. I would look at transimpedance amplifier design to start. \$\endgroup\$
    – Luke Gary
    Aug 3, 2022 at 1:23
  • \$\begingroup\$ Are you sure the polarity of the photodiode is correct? Voltage to correct pins of op-amp? Is the inhibit pin connected properly? Is the input of the Raspberry Pi loading down the signal? \$\endgroup\$
    – PStechPaul
    Aug 3, 2022 at 1:28
  • \$\begingroup\$ @PStechPaul Ive tested my PiPico ADC input by feeding 3.3v directly from a power supply, and it reads out 3.3v correctly so I dont think its loading down the signal, Ive tried the polarity of the photodiode both ways to make sure ive got the anode and cathode correct \$\endgroup\$ Aug 3, 2022 at 1:48
    \$\begingroup\$ Show us your actual circuit, including the photodiode & power supply, not the standard example opamp configurations. \$\endgroup\$
    – brhans
    Aug 3, 2022 at 2:08
You need enough power supply voltage to accommodate your input and output voltages. You have not specified what you are using, but if you are using a single supply such as 3.3V/ground you can only get positive voltages output. The open-circuit voltage you measured probably has a short circuit current in the 0.1-1uA range under normal ambient lighting. You can get a rough measure of it with a multimeter.
If you use a transimpedance amplifier configuration you'd want to do something like this (plus a bypass capacitor on the power):
Try something in the M\$\Omega\$ for Rf.
Here D1's negative current in photovoltaic mode works into a virtual ground with the current supplied via Rf. C1 helps with stability. The output is 1V/uA of PD current with a 1M\$\Omega\$ resistor and proportionally more for higher values of Rf.
  • \$\begingroup\$ Thank you for posting this! I got the best response so far, but there is still something wrong. I used a 1Mohm resistor and 220pf capacitor, and got 0.3 v output in the dark and 0v when I turn a light on. Would it be helpful if I posted a picture of my circuit? Im 99% sure Im using the right pins on the op amp but you never know \$\endgroup\$ Aug 3, 2022 at 1:42
    \$\begingroup\$ Try flipping the PD. \$\endgroup\$ Aug 3, 2022 at 2:01
  • \$\begingroup\$ Flipping the pd (cathode to ground, anode to -input/resistor/capacitor) gives me the original values I had, 0.1v in the dark and .34v with a flashlight on it. arg! \$\endgroup\$ Aug 3, 2022 at 2:13
  • \$\begingroup\$ Maybe let's see the circuit. You could also try 10M. \$\endgroup\$ Aug 3, 2022 at 2:18
    \$\begingroup\$ Try replacing the PD with a 1.5V battery in series with a resistor the same value as Rf (eg. 1M). You should get 1.5V in one direction and 0V in the other. \$\endgroup\$ Aug 3, 2022 at 3:19
It looks like a photodiode needs to be reverse biased with about 1-5 VDC for it to operate, and then it will produce up tp 400 uA when exposed to light. Here is an article that explains a bit:
https://www.gadgetronicx.com/working-photodiode-applications/
Photodiode
This is the circuit they recommend:
Photodiode circuit
So, based on that, try again, and you should have success.
[edit]Your photodiode has output of 0.04 to 0.14 A/W, where W is the detected optical power. I would expect W to be around 1 mW so that would correspond to 40-140 uA. Through the 100k resistor this would be 4-14 volts. If the circuit is too sensitive, try maybe 20k.
  • \$\begingroup\$ Ive tried many variations of resistors for this circuit, and got no responsiveness to light. I got a consistent output of ~.5v regardless of resistor changes on R1 and R3, which is the same value I get if I take the diode out completely. When I flip the diode I get consistent ~1.4v (no light responsiveness either) so I think the diode is working b/c I see such a big change when I flip the anode /cathode, but am not sure why none of these variations in resistors are making a difference \$\endgroup\$ Aug 3, 2022 at 15:10
