I am a newbie in PCB designing and started designing PCBs recently. I came across a concept called via stitching which is to achieve increased current carrying capacity of the board. I looked for the references on the internet but did not find the ones which will clear the doubts that I had. The doubts that I have regarding the via stitching are:
- If adding vias is intended for increased current capacity then what number of vias should be added and what should be its diameter?
- If there is not enough space to add bigger diameter vias, then can a large number of small-sized vias be used?
- Is there any calculation regarding the number of vias we need to put for a specific current requirement?
- Is there any guidelines regarding the clearances between each via if we have space constraints?
It is true that the board layout depends on our application. My design is a two-layer board and I have added separate power planes on both layers for high-current carrying components. Do I need to add vias there to connect the power planes on both layers (the components are through-hole)? And in case we are adding vias to connect multiple power planes, then will it be a good idea to stitch multiple vias to give more buffer to the board's current carrying capacity?
