I am trying to turn off my N-channel MOSFET which is driven by a charge pump.
It takes too long to discharge the pump through the gate-resistor to ground, therefore the power dissipation is very high.
Any advice to lower the amount of time it takes to turn the MOSFET off?
Downsizing the charge pump and the resistor both leads to a shorter time, but then the charge pump can't reach its potential voltage.
Actively discharge C2
Assuming you switch the charge pump on and off with some sort of logic, derive the off control as the complement of that.
