I'm designing a 4-bit TTL computer and I want to use the CY62256N for system RAM.
As you see, the computer is a 4-bit computer which means the main data bus is only 4 bits wide. The CY62256N is an 8 bit x 32k SRAM, 8 of the data pins are used for both input and output.
The problem is that the RAM data line is going to be directly connected to the main data bus, so there are 4 I/O pins of the CY62256N that are not going to be connected.
Since those are inputs I thought about tying them to ground, but those are output too, so I'm afraid that if I connect them to ground they can damage the RAM by overcurrent on the output. The PCB of the computer is going to be pretty small and has barely any space left, so I don't think that I can add some resistors.
So should I tie those 4 I/O pins to ground or just leave them floating?
