The mission is to find i0 in the image below. The answer is 1.78 A.
I first combined the 1 and 4 Ω resistors to a 5 Ω resistor and combined the 3 and 6 Ω resistors to a 2 Ω resistor. Then I moved the current source to the side making a circuit like below:
From the left, there are four meshes. The first mesh has a clockwise mesh current of 5 A. I'll name the second mesh current i1, the third mesh current i2, both flowing clockwise. The fourth mesh current flows anti-clockwise with a current value of 3 A.
From the second and third mesh, we can get equations like below:
$$ 2(i_1-5)+5+7(i_1-i_2)=0 \\ 7(i_2-i_1)+5(i_2+3)=0 $$
Solving the system of equations, we get:
$$i_1=-\frac{45}{59} \\ i_2=-\frac{100}{59}$$
This means that the current flowing in the 7 Ω resistor is:
$$i_o=\frac{55}{59}=0.93$$
Which is the wrong answer. What have I done wrong here? I checked the current in the other resistors using the result to validate the answer and it all added up to 8 A, so I assumed the answer I got was correct, but it wasn't.
