I saw the following instantiation in a Verilog testbench:
`define width 8
scale_mux #(`width) m1 (.out(out), .sel(sel), .b(b), .a(a));
I don't know what the "#" means here. Does it replace the parameter declared in scale_mux module with the parameter "width" in test bench? Or does it mean instantiating the scale_mux module 8 times?
The description of scale_mux is as follows:
module scale_mux (out, sel, b, a);
parameter size = 1;
output [size-1:0] out;
input [size-1:0] b, a;
input sel;
assign out = (!sel) ? a :
             (sel)  ? b :
             {size{1'bx}};
endmodule
Well, after some searching, I found a possible explanation:
When we want to instantiate a Verilog module with parameter, like this:
parameter size = 1;
input sel;
                           (sel)  ? b :
                           {size{1'bx}};
endmodule
The parameter here is size = 1.
Instantiating this module like this:
is equivalent to
scale_mux #(.size(8)) m1 (.out(out), .sel(sel), .b(b), .a(a));
So it is to override the parameter, not copying the referred module 8 times.
REFERENCE:
1.https://fpgatutorial.com/verilog-generate/
