I have a set of test vectors saved in a csv file and formatted as follows:
0010,1000,1010
1110,0101,0001
1001,0001,0000
These are randomly generated and can be of any arbitrary length or number. Here the number is 3 (3 vectors per row) and length is 4 (4 bits for each vector).
I wanted to read these vectors in Verilog and apply them to an array of instantiated modules. In other words, 0010 will be applied to the first instance, 1010 to the third instance. Next apply 1110 to first instance, 0001 to the third and so on.
We have three latches (Lat
module) and we are generating 3 instances of it in Lat_array
module. I want the operation be like: first indexed instance gets the first 4 bits, second instance gets the second set of four bits and the final instance gets the last four bits in the row. All of them get the 4 bits at the same time and output at the same. After that, the data in the next row is applied in the same order as another input test vector. Below the waveforms are posted.
I tried the following code. I could test a single module, but I don't know how to test several instances using the test vectors above. Could you please guide me where I doing wrong and how to implement this?
Top level module:
module Lat_array #(parameter number =3, parameter length = 4)(ins, clks, resets,outs);
input [length- 1:0] ins;
input clks, resets;
output [length-1:0] outs;
generate
genvar i;
for (i=0; i<number; i=i+1) begin
Lat lat(
.clk(clks)
,.reset(resets)
,.in(ins)
,.out(outs)
end
endgenerate
endmodule
The Lat module:
module Lat #(parameter length = 4)(in, clk, reset,out);
input [length- 1:0] in;
input clk, reset;
output [length-1:0] out;
reg [length-1:0] res;
always @ (posedge clk) begin
if (!reset)
res <= 0;
else
res <= in;
end
assign out = res;
endmodule
Testbench:
`timescale 1ns/1ps
module tb;
parameter number = 3;
parameter length = 4;
reg [length-1:0] in;
reg clk, reset;
wire [length-1:0] out;
Lat_array #(.number(number), .length(length)) lat_insts (.ins(in), .clks(clk), .resets(reset), .outs(out));
initial begin
reset <=0;
clk <=0;
end
always @(clk) #100 clk <= ~clk;
reg [length-1:0] temp;
reg [length- 1:0] test_in [(3*number)-1:0];
integer f, k;
initial begin
#500 reset <= 1;
in <= 0;
f = $fopen("test.csv", "r");
for (integer i = 0; i < 3; i = i + 1)
//while(! $feof(f))
begin
for(integer j = 0; j < number; j = j + 1)
begin
k = $fscanf(f,"%b,",temp);
$display("%b", temp);
test_in[j] = temp;
end
#10; in = test_in[i-1];
end
#200 reset <=0;
$monitor("in=%b, out=%b", in, out);
#1000 $finish;
end
endmodule
