I’m building a test bench for some aircraft instruments and I was testing a Bendix 1964771-3 inverter (24 VDC) bought from eBay.
The inverter should have outputs of 129VAC at 370Hz and 12VAC/18VAC at 1110 Hz. The inverter was marked as untested but I was told it was removed from a working aircraft.
I powered up the inverter and checked the outputs with a Unit-T UT33C multimeter, but I did not get any output.
I suspect maybe only the expensive like Fluke, Omega, etc. can measure such high frequency voltages. Could this be the case? Just as a precaution I tried using a neon voltage tester and it immediately lit orange light.
  • \$\begingroup\$ Rectify to DC and measure on DC with your meter as an alternative proof of voltage presence. \$\endgroup\$
    Aug 6 at 14:02
  • \$\begingroup\$ I measured the 3dB bandwidth on a 20 dollar generic DMM and got about 1.5 KHz. Yours could be anything but I doubt the drop off is so sharp that you would measure 0V at 370 Hz. \$\endgroup\$ Aug 6 at 14:06
  • \$\begingroup\$ You are basically asking us what reads in your multimeter manual what AC frequency range it can measure. Have you read your multimeter manual? \$\endgroup\$
    – Justme
    Aug 6 at 14:09
  • \$\begingroup\$ @Andyaka I'm going to try this now. Thanks for the suggestion. \$\endgroup\$
    – RSB
    Aug 6 at 14:15
  • \$\begingroup\$ Make sure you add a light load so that maybe a few milliamps are taken but, calculate the resistor load power dissipation with what you might expect to see if the voltage is present. \$\endgroup\$
    Aug 6 at 14:17
The Unit-T UT33C user's manual says it can handle AC up to 400Hz and 500V.
It can probably manage the 400Hz (if it meets its specifications.) It will give totally wrong results for the 1110Hz - either nothing or way too low.
