I was hoping to use the LM2731Y boost converter to step up 3.6V to 7V, but I'm unclear if this will work for my load requirements. I will likely have a fairly low current draw (<50mA) and there is a section in the datasheet that lists the minimum output voltage under load that I don't think would meet my 7V output requirement. However, there is a 3.2V to 5V configuration in the application section that seems to counter this, since it show lower load currents in the efficiency vs load current graphs.
Are there minimum load requirements for boost converters?
What does Vout(min) mean in this datasheet?
