I'm designing a PCB to use a 4.3" LCD TFT display. The LCD has a 24-bit RGB parallel interface. The design needs to be EMC compliant.
My question is, what are the design requirements I should pay attention to when routing the board?
The LCD will be running at 12 MHz, and the resolution is 480x272. The PCB spec is 2 layer 1 Oz copper board. I have identified that the trace impedance is required to be 50 Ω. I'll try to keep the trace length as short as possible (less than 50 mm).
These are the questions that I have so far:
Do I need termination resistors on the RGB data lines? How do I calculate the required resistor values?
Do I need to length-match the data lines with respect to the clock signal?
Are there any other requirements that I should consider in my design?
