The following is a sata3 data cable picture taken from wikipedia
There are 4 wires for each differential pair, and I guess the two silver-colored cables are grounds, and the two bronze-colored cables are differential pairs.
My question is, what's the benefit of using two ground cables instead of one?
Thanks!
Your picture actually shows four ground wires (two on each side of each of the signal pairs). On the SATA connector, the middle two wires are connected to a single pin, so the connector has three ground pins.
The reason for these four wires is complex (mostly to do with crosstalk); it is well explained here: Why do cables have multiple grounds?
  • \$\begingroup\$ Thanks @Paul. It seems that two main purposes were mentioned in that thread, i.e., to alleviate both impedance mismatching (causing reflection) and magnetic field overlap (causing crosstalk). \$\endgroup\$
    – bruin
    Aug 11, 2022 at 1:30
  • \$\begingroup\$ You are right, although mismatching could also have been solved in other ways. \$\endgroup\$
    – Paul
    Aug 11, 2022 at 12:30
