I used a modified code from an example for SPI communication "spiloopback" from Texas Instruments, where I tried to write data in the registers of W5500 and then read those data.
uint8_t masterRxBuffer1[SPI_MSG_LENGTH];
uint8_t masterTxBuffer1[SPI_MSG_LENGTH] = {0x00, 0x26, 0x14, 0xFF, 0xFF, 0xFF, 0x00,0x00};
uint8_t masterRxBuffer2[SPI_MSG_LENGTH];
uint8_t masterTxBuffer2[SPI_MSG_LENGTH] = {0x00, 0x26, 0x16, 0x00, 0x00, 0x00, 0x00,0x00};
uint8_t slaveRxBuffer1[SPI_MSG_LENGTH];
uint8_t slaveTxBuffer1[SPI_MSG_LENGTH];
uint8_t slaveRxBuffer2[SPI_MSG_LENGTH];
uint8_t slaveTxBuffer2[SPI_MSG_LENGTH];
Block Select Bits = 00010
MODE = 00
Offset Address = 0x0026
Written data = 3 x 0xFF
In the oscilloscope:
  • 1st signal = clock
  • 2nd signal = MOSI
  • 3rd signal = CS/SS
  • 4th signal = MISO
It worked somewhat but it was very inconsistent, by that I mean that every time I reset the board I get a different read and I don't know why.
W5500 datasheet
The Read command doesn't seem to correspond with the write command.
Write Command: 0x14
  • BSB[4:0] = 00010 (Selects Socket 0 TX Buffer)
  • RWB = 1 (Write)
  • OM[1:0] = 00 (Variable Data Length Mode, N-Bytes Data Phase (1 ≤ N))
Read Command: 0x16
  • RWB = 1 (Write)
  • OM[1:0] = 10 (Fixed Data Length Mode , 2 Byte Data Length (N = 2))
I imagine the correct Read Command to be: 0x10
  • RWB = 0 (Read)
  • OM[1:0] = 00 (Variable Data Length Mode, N-Bytes Data Phase (1 ≤ N))*
Image taken from the Datasheet.
