In my integrator circuit, I added one feedback resistor R2 and one bias compensation resistor R3. The values of the components are values I have measured before I applied them on this PCB Evaluation Board.
All components are somewhat of standard SMD components lying around my soldering iron. I calculated the gain with this formula:
\$ \text{gain}_\text{calc} = \frac{1}{2\pi f R_1 C_f} \approx \underline{\underline{2.9}}\$
The simulation with LTspice gives me the same value.
But on my PCB circuit I measured a different gain.
\$\text{gain}_\text{meas} = \frac{V_{\text{out_rms}}}{V_{\text{in_rms}}} = \frac{5.793\text{ V}}{2.135\text{ V}} \approx \underline{\underline{2.7}}\$.
This leaves me with a voltage difference of Vpp ≈ 1.127 V, just a bit too much for my gut feeling.
What can cause this difference, and where should I revisit my doings so far to have the values from the simulation equal to the values in the real world?
