Introduction
I am developing a PCB which has a 12VDC unregulated power supply connected to an LVR L7805CV from which a couple of shift registers (74HCT595) are being powered. The problem I have is that when I probe the main line (230VAC) connections with a multimeter to measure voltage, the shift registers change outputs due to noise. This happens every time on an initial touch with a probe, however the noise is gone once contact has been established with the probe.
I assume that my multimeter acts as an antenna that introduces noise into the circuit, however I've been unable to fix this issue.
Some might say, well don't touch it with a multimeter, however I believe the problem is much more intrinsic. I believe that the same issue will occur if a high load noisy equipment is connected on the same ac line as my PCB.
Circuit
The circuit is little bit more complicated than I described above. I basically have a transformer stepping down from 230VAC to 18VAC with split secondaries from which I obtain 24VDC and 12 VDC accordingly. I put a an X class capacitor C5 to filter any possible noise coming from the main line. I also put pretty bulky smoothing capacitors to avoid high ripple. The LVR is loaded at 100mA max. and the transformer is loaded at 550mA max.
Design layout
I separated the board into high(230VAC) and low voltage zones separated by a minimum of 8mm distance, optocouplers, relays or main transformer. I designed the LVR according to datasheet, putting capacitors C1, C2 and C3 as close as possible. I didn't put a ground plane in the low voltage zone because I thought I didn't need one due to low frequency signals. All ground traces are branching out from a single point of the circuit preventing ground loops. All power lines were put close to each other on separate layers in order to avoid any radiated noise from the board.
The main problem
Probing when PCB is not powered
Whenever I connect the probe, I can see peaks on the input and output from the LVR going up to ~800mV. Please note that both images were not shot concurrently.
Probing when PCB is powered
Unlike previously, when PCB is powered the peaks go much higher with values up to ~10-15V. I believe that due to this high noise in the 5VDC power supply my shift registers change outputs. Please note that both images were not shot concurrently
Question
I am unable to address the problem since I don't know what is the reason that causes it. Is this an issue due to resonance in the circuit, is it an EMC issue, is it a poor design layout or maybe something else? I would really be grateful if you could help me come to a solution to this problem or perhaps suggest literature.
What has already been tried
- At first I thought that the multimeter was faulty drawing too much current and causing voltage drop. I tried another multimeter and the problem persisted.
- I was missing some decoupling capacitors on my shift registers so I added 1 µF (0805) and 47 nF (0603) in parallel as close as possible to the VCC pin. I thought this was the source of the problem but it didn't help.
- Then I thought that my LVR was unstable so I added 100 uF electrolytic caps on the input and output. While this reduced the probability of output switching, yet it still occurred occasionally.
- In order to avoid software or MCU problems I disconnected the MCU completely to isolate the problem. All shift register inputs were connected to ground. Therefore I concluded that my MCU or software was not the problem.
- I thought that my C5 EMC capacitor was resonating with the transformer's primary. I removed it but the problem persisted so I returned it.
- I tried putting some series resistors to the shift registers' DATA, LATCH and input pins to mitigate noise, however the problem persisted so I removed them.
Update 1
- As @ PStechPaul suggested, I tried putting 180k resistor between N and GND to check if it helps. I even tried 10k on a powered off PCB. Nevertheless I could still see the same peaks and the problem persisted
- Considering the suggestion from @Jens, I also tried testing if any ESD flows from my DMM lead through the transformer by putting 400V breakdown voltage TVS diode between L and N. I also added a ferrite bead in series of L, however the problem persisted and I could still see the same peaks.
The last test, lead me to believe that this transient flows through a different path. Therefore, I completely removed the fuses from the L traces, disabling any conductive path to my PCB components from the L lines. Then I performed the DMM test by touching the L line on a powered off PCB and I could see the same ~500mV peaks as before.
This lead me to a conclusion that I am probably discharging myself when I am touching the PCB and the transient couples capacitively with the whole board. I am not even sure if this can be fixed. I hope if someone could tell me how can I avoid this capacitive coupling interfering with my shift registers
Update 2
- As @Jens suggested, I tried putting RC filters on input lines with 100 Ω resistor and 100 nF capacitor. I could see the signals clean on scope, however registers still went haywire when touching with my multimeter.
This led me to conclusion that I have an intrinsic design problem with my board and therefore I'd like to finalize this post with your recommendations (answers) on design improvements that may help reduce the shift register noise.
I believe that one of the main problems with the shift registers is noise and bad decoupling. Here are my thoughts on this:
- I would introduce a ground plane in the LV zone in order to avoid all the ground traces being led throughout the board.
- I would add schmitt triggers in front of each input line.
- I would add RC filters in front of data, latch and clk signals before each schmitt trigger input. R=100 Ω and C=100 nF.
- Current shift registers were powered from 5V and driven with 3v3 signals. Hence the TTL version 74HCT. Since ULN2003 from TI can be driven with 3V3 signals, I decided to replace the shift registers with the CMOS version and power it from 3V3 in order to increase noise margin.
- I had considered using I/O expander instead of shift registers, however the I2C signals would go through ~70 cm (23 inches) flex ribbon cable therefore I ruled it off in order to avoid potential problems with I2C due to cable capacitance.
- Of course the missing decoupling capacitors I had to add afterwards will be added as well. I was planning on putting 100 nF (0603) and 1 uF (0805) ceramic ones.
What is your opinion on this and what else would you add?
