I'm working on a project which should connect an FPGA to some MIPI-CSI2 signals.
There are ten cameras, each one using four differential pairs plus one pair for the differential clock.
I'm routing the signals onto different layers. Each layer has one GND plane layer under it. By doing that, some of the signals need to cross each other in different layers.
Is it going to be problematic for those signals that cross each other in different layers? If so, what would be the solution?
This is my Stack Up:
Top Layer: Signals
Layer 2: Signals
Layer 3: GND
Layer 4: Signal
Layer 5: GND
Layer 6: Power
Layer 7: Gnd
Layer 8: Signals
The picture shows one of these crossings:
New Stack up:
Signal1
GND
Signal2
GND
Power
Signal3
GND
Signal4
  • \$\begingroup\$ What layers are your dark and light colored traces on, and is there a ground or power plane between them? \$\endgroup\$
    – The Photon
    Aug 19, 2022 at 16:18
  • \$\begingroup\$ The yellow one is in layer 2, the other one is in layer 4. I reserved layer 3 and layer 5 for GND. This is my Stack up: Top Signal / layer 2 signal / Layer 3 GND/ Layer4 Signal/ Layer 5 GND/ Layer 6 Power/layer 7 Signal/ Bottom Layer GND \$\endgroup\$ Aug 19, 2022 at 16:44
  • \$\begingroup\$ @SemiElectron Please edit that into your post - comments are ephemeral and harder to read, while the post body is durable and can contain richer formatting like newlines and lists that can make your stackup easier to read. \$\endgroup\$
    – nanofarad
    Aug 19, 2022 at 16:51
  • \$\begingroup\$ Layer 1 doesn't have a good reference plane. All signal layers should be adjacent to a ground plane. Layer 2 should definitely be GND. \$\endgroup\$
    – td127
    Aug 19, 2022 at 20:45
  • \$\begingroup\$ A lot of answers to your questions about stackups : youtube.com/watch?v=ySuUZEjARPY. See the end of the video for stackups \$\endgroup\$ Aug 19, 2022 at 21:21
If you have a ground plane in between, you should be fine.
  • \$\begingroup\$ @ Marcus Muller Thank you SO much. Would you please look at my question(I edited and updated it) and see if my Stack up is make sense? \$\endgroup\$ Aug 19, 2022 at 16:57
The only time it's really an issue as if the differential pairs are on to inner layers that are adjacent. In that case only crossing near other differential pairs is not that big a deal as your only adding less than one picofarad of capacitance between the differential pairs.
One thing you may want to do is try and keep parallel differential pairs at least 2x differential pair width especially for long parallel runs as paralell differential pairs can generate crosstalk.
If you do have to run high speed signals next to each other only do it for work distances to minimize crosstalk and capacitive coupling.
  • \$\begingroup\$ Thank you, "Voltage Spike" for your comment. My understanding from your comment And Marcus Muller is that if I use the GND layer under each Signal Layer, It should be fine. correct? I edited my original question with the new stack-up. \$\endgroup\$ Aug 20, 2022 at 15:05
New stack-up looks good to me.
Below statements are taken from this app note from TI.
The entirety of any high-speed signal trace should maintain the same GND reference from origination to termination. If unable to maintain the same GND reference, via-stitch both GND planes together to ensure continuous grounding and uniform impedance. Place these stitching vias symmetrically within 200 mils (center-to-center, closer is better) of the signal transition vias.
