I found this question and would like to know whether my solution is correct.
I need to work out the current through each one of these resistors. enter image description here
I got the following values for the current:
  • I1 = 8.75 A
  • I2 = 3.5 A
  • I3 = 3.5 A
  • I4 = 5.25 A
  • I5 = 7 A
I couldn't find this question and it's solution anywhere, so I am not sure whether I have done this correctly. If someone could check this for me that would be brilliant.
Thanks in advance
  • \$\begingroup\$ Welcome! Did you try to simulate it to get the correct answer? \$\endgroup\$
    – winny
    Commented Aug 22, 2022 at 12:25
  • \$\begingroup\$ Thanks, yh I put the values back in to the equations I got from kirchhoff's 1st law, and they seemed to check out. But I am still very new to this and would like to know for sure whether I arrived at the correct answer. \$\endgroup\$ Commented Aug 22, 2022 at 12:30
  • \$\begingroup\$ I’m voting to close this question because there is no asker try \$\endgroup\$ Commented Aug 22, 2022 at 12:39
Your answers for current flows are incorrect: -
  • \$\begingroup\$ Hi, thanks for your response, what tool did you use to generate this? \$\endgroup\$ Commented Aug 22, 2022 at 12:32
  • \$\begingroup\$ Micro-cap 12 (a free simulator). \$\endgroup\$
    Commented Aug 22, 2022 at 12:49
    \$\begingroup\$ Thanks, I figured what I did wrong as well, appreciate the help a lot. \$\endgroup\$ Commented Aug 22, 2022 at 12:52
