I am creating a current sink that can draw a step current from the Vnode of the circuitry in blue.
The reason to draw a step current from Vnode is that I need to measure the characteristic impedance of the TLIN by drawing a sudden current by applying a VCCS in red (voltage controlled current source) with a step voltage.
However I tried to combine these 2 circuitry as below, red and blue. The Vg of the NMOS is around 15V positive, but since there is no voltage difference between source and drain, the current read at I_probe1 and I_probe5 are nearly zero.
How should I modify this circuit so can get a step current from Vnode so I can measure the characteristic impedance of TLIN when a sudden current is drawn from Vnode with a VCCS?
